9200L Switch crashed after command
NicP
I was trying some commands in a unsourced interface template and with one command it managed to crash my switch.
The template is "dot1q fallback <WORD>" and "no dot1q fallback"
The logs show that a watchdog timer failover is triggered and the switch reboots itself afterwards.
Switch Ports Model SW Version SW Image Mode
* 1 28 C9200L-24P-4X 16.9.4 CAT9K_LITE_IOSXE INSTALL
I don't have a service contract so I made this post to address the problem.
Reza Sharifi
Most likely a bug in the IOS you are running is causing the switch to crash. You would need a service contract to be able to open a ticket with TAC and upgrade the IOS.
Leo Laohoo
CSCuz80524
Thank you Leo,
There is only one thing. In my case it crashed when i configured a unsourced template.
Nevertheless I will try the new software version soon.
