9200L switch crashinfo question.
JUNHOLEE95720
Why is the crashinfo file found on the new switch?
Crash info can vary in capacity.
4096, 8192, 36000
You mean the 36000 switch is even more problematic?
The contents of the tracelog folder of CrashInfo are as follows.9200L switch crashinfo question.
Switch#dir crashinfo:tracelogs
Directory of crashinfo:/tracelogs/
 7646  -rw-              936  Oct 26 2020 04:41:27 +00:00  install_engine_R0-0.1392_0.20201026044044.bin.gz
 7623  -rw-              851  Oct 26 2020 04:41:20 +00:00  btman_pmanlog_F0-0.9669_0.20201026044119.bin.gz
 7633  -rw-             1662  Oct 26 2020 04:41:27 +00:00  flashutil_R0-0.5977_0.20201026044107.bin.gz
 7637  -rw-              800  Oct 26 2020 04:41:27 +00:00  tamd_proc_R0-0.7468_2.20201026044118.bin.gz
 7642  -rw-             1641  Oct 26 2020 04:41:27 +00:00  flashutil_R0-0.4398_0.20201026044052.bin.gz
 7770  -rw-             1046  Oct 26 2020 04:41:27 +00:00  issu_boottime_R0-0.4101_0.20201026044051.bin.gz
 7651  -rw-              615  Oct 26 2020 04:41:27 +00:00  tamd_proc_R0-0.7468_3.20201026044125.bin.gz
 7763  -rw-              620  Oct 26 2020 04:41:27 +00:00  tamd_proc_R0-0.7468_4.20201026044125.bin.gz
 7764  -rw-              835  Oct 26 2020 04:41:27 +00:00  binos_R0-0.4062_0.20201026044051.bin.gz
 7766  -rw-              619  Oct 26 2020 04:41:27 +00:00  tamd_proc_R0-0.7468_5.20201026044126.bin.gz
 7340  -rw-            21539  Oct 26 2020 04:42:28 +00:00  dmesg
 7765  -rw-              769  Oct 26 2020 04:41:27 +00:00  unified_rsync_udev_R0-0.9641_0.20201026044119.bin.gz
 7767  -rw-             1649  Oct 26 2020 04:41:27 +00:00  flashutil_R0-0.5975_0.20201026044107.bin.gz
 7769  -rw-             1639  Oct 26 2020 04:41:27 +00:00  flashutil_R0-0.5982_0.20201026044107.bin.gz
 7768  -rw-              515  Oct 26 2020 04:41:27 +00:00  inst_issu_check_R0-0.5377_0.20201026044056.bin.gz
 7776  -rw-              734  Oct 26 2020 04:41:27 +00:00  tdl_boottime_R0-0.4128_0.20201026044051.bin.gz
 7771  -rw-             1069  Oct 26 2020 04:41:27 +00:00  tamd_proc_R0-0.7468_0.20201026044114.bin.gz
 7773  -rw-             1659  Oct 26 2020 04:41:27 +00:00  flashutil_R0-0.5976_0.20201026044107.bin.gz
 7341  -rw-               10  Oct 26 2020 04:42:28 +00:00  timestamp
 7772  -rw-              361  Oct 26 2020 04:41:27 +00:00  inst_publish_retrieve_sw_sets_R0-0.4326_0.20201026044052.bin.gz
 7774  -rw-              634  Oct 26 2020 04:41:27 +00:00  tamd_proc_R0-0.7468_1.20201026044117.bin.gz
 7775  -rw-             1368  Oct 26 2020 04:41:27 +00:00  run_ioxn_secure_dir_sh_pmanlog_R0-0.9951_0.20201026044120.bin.gz
 7777  -rw-              359  Oct 26 2020 04:41:27 +00:00  inst_rollback_timer_R0-0.5622_0.20201026044105.bin.gz
 7778  -rw-             1616  Oct 26 2020 04:41:30 +00:00  auto_upgrade_client_sh_pmanlog_R0-0.11804_0.20201026044128.bin.gz
 7779  -rw-             1491  Oct 26 2020 04:41:35 +00:00  droputil_R0-0.3752_0.20201026044049.bin.gz
 7780  -rw-              656  Oct 26 2020 04:41:35 +00:00  tamd_proc_R0-0.7468_6.20201026044126.bin.gz
 7781  -rw-            10863  Oct 26 2020 04:41:56 +00:00  IOSRP_R0-0.7335_0.20201026044150.bin.gz
 7782  -rw-            18036  Oct 26 2020 04:41:56 +00:00  plogd_R0-0.19370_0.20201026044155.bin.gz
 7783  -rw-             1316  Oct 26 2020 04:41:56 +00:00  reflector_R0-0.3755_0.20201026044049.bin.gz
 7330  -rw-             1616  Oct 26 2020 04:42:01 +00:00  auto_upgrade_client_R0-0.12666_0.20201026044131.bin.gz
 7331  -rw-            11059  Oct 26 2020 04:42:10 +00:00  pvp_R0-0.6479_0.20201026044111.bin.gz
 7332  -rw-            17077  Oct 26 2020 04:42:17 +00:00  IOSRP_R0-0.7335_1.20201026044155.bin.gz
 7333  -rw-              366  Oct 26 2020 04:42:26 +00:00  cfgwr_R0-0.27747_0.20201026044226.bin.gz
 7334  -rw-             1337  Oct 26 2020 04:42:26 +00:00  droputil_R0-0.3752_1.20201026044135.bin.gz
 7335  -rw-              364  Oct 26 2020 04:42:26 +00:00  cfgwr_R0-0.27745_0.20201026044226.bin.gz
 7336  -rw-              366  Oct 26 2020 04:42:26 +00:00  cfgwr_R0-0.27748_0.20201026044226.bin.gz
 7337  -rw-              365  Oct 26 2020 04:42:26 +00:00  cfgwr_R0-0.27749_0.20201026044226.bin.gz
 7338  -rw-              366  Oct 26 2020 04:42:26 +00:00  cfgwr_R0-0.27746_0.20201026044226.bin.gz
 7339  -rw-             4775  Oct 26 2020 04:42:28 +00:00  smand_R0-0.18229_0.20201026044154.bin.gz
 7342  -rw-             4076  Oct 26 2020 04:42:29 +00:00  smand_R0-0.18229_1.20201026044228.bin.gz
 7343  -rw-            15545  Oct 26 2020 04:42:57 +00:00  IOSRP_R0-0.7335_2.20201026044217.bin.gz
 7344  -rw-              629  Oct 26 2020 04:46:20 +00:00  plogd_F0-0.16820_0.20201026044151.bin.gz
 7345  -rw-             1216  Oct 26 2020 04:46:20 +00:00  fman_fp_image_pmanlog_F0-0.17957_0.20201026044152.bin.gz
 7346  -rw-             1255  Oct 26 2020 04:46:20 +00:00  plogd_pmanlog_F0-0.16387_0.20201026044150.bin.gz
 7347  -rw-            24879  Oct 26 2020 04:46:27 +00:00  create_luid_file_db_R0-0.28648_0.20201026044627.bin.gz
 7348  -rw-            41910  Oct 26 2020 04:46:51 +00:00  create_luid_file_db_R0-0.28648_13.20201026044651.bin.gz
 7349  -rw-            22700  Oct 26 2020 04:46:50 +00:00  create_luid_file_db_R0-0.28648_10.20201026044649.bin.gz
Leo Laohoo
Post the complete output to the following commands:
sh version
sh log on switch active up detail
Hello
I tested 100 new 9200Ls, and when I used the dir crashinfo command all the equipment was there.
However, some devices were 4096 bytes and some were 36000 bytes.
It seems normal to have such a small amount of crashinfo information.
I was wondering if this was correct.
We cannot provide the log right now. It is far from the scene.
Thank you.
Mark Elsen
 - Check current software version installed, make sure to use a recommended release for your platform.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
