03-06-2021 05:59 AM - edited 03-06-2021 06:46 AM
I have a 9300 switch, and after boot stuck in rommon mode prompt switch:
How can I make the switch to boot in normal mode. I have the required IOS in a FTP server. Please advise.
switch: boot
WARNING: Bootable URL's in BOOT variable not found or exhausted.
Please check the ROMMON configuration or boot command usage.
switch: dir flash:
Tried the following link as well, no luck,
Step 1
From your PC, download the software image file (image.bin ) from Cisco.com.
Step 2
Load the software image to your TFTP server.
Step 3
Connect your PC to the switch Ethernet management port.
Step 4
Unplug the switch power cord.
Step 5
Press the Mode button, and at the same time, reconnect the power cord to the switch.
Step 6
From the bootloader (ROMMON) prompt, ensure that you can ping your TFTP server.
Set the IP address switch: set IP_ADDRESS ip_address subnet_mask
Example:
switch: set IP_ADDRESS 192.0.2.123/255.255.255.0
Set the default router IP address switch: set DEFAULT_ROUTER ip_address
Example:
switch: set DEFAULT_ROUTER 192.0.2.1
Verify that you can ping the TFTP server switch: ping ip_address_of_TFTP_server
I can not ping from switch to laptop
03-06-2021 09:08 AM
- Perhaps this thread can help :
https://community.cisco.com/t5/switching/no-switch-boot/td-p/3994955
M.
03-06-2021 09:14 AM
Cat 9300 has USB Port
Get the image 16.12.X .bin file
Format USB with FAT32 - copy the .bin file to USB.
Plug the USB and boot from USB and copy to flash.
