9407 POWER ISSUE - Insufficient POWER error
Greetings,
I have 9407  core switch with 4 modules and 2 sup. We removed 1 old SUP and installed 2 new SUP, after we power up it gives below message. I have tried starting the core with only 1 module as well, but still it gives the same error.
Kindly advice.
Power Fan States
Supply Model No Type Capacity Status 1 2 3 4
PS1 UNKNOWN-PFU AC n.a. err-disable n.a. n.a. n.a. n.a.
PS2 UNKNOWN-PFU AC n.a. err-disable n.a. n.a. n.a. n.a.
PS Current Configuration Mode : Combined
PS Current Operating State : Combined (Insufficient Input Power)
Power supplies currently active : 0
Power supplies currently available : 0
Power Summary Maximum
(in Watts) Used Available
System Power 1340 0
Inline Power 0 0
Total 1340 0
System needs 1340 watts additional power.
*Mar 2 00:16:20.141: %CMRP_PFU-3-PWR_MGMT_ALARM: R0/0: cmand: WARNING: System does not have sufficient
input power for minimum reliable operation requiring 1340 watts. The system needs 1340 watts of additional power.
10 Replies 10
marce1000
 - Could be a bogus message similar too https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvq55973  , use latest advisory software version on the 9407 (if applicable) , check if that can help ,
 M.
Leo Laohoo
The chassis needs, a minimum, of two power supplies.
Dear Leo
I have two power supplies and the power status on it is green.
Kindly advice.
Reza Sharifi
Can you provide the output of show power?
Dear Reza,
Above is the output of show power only: below is the output-
#show power
Power Fan States
System Power 1340 0
Inline Power 0 0
Total 1340 0
Hi Syed,
This maybe a software bug, as we can't see the numbers in the output. If all working correctly, you should see something like below output. So, you may want to open a ticket with Cisco TAC on this and have them take a look.
PS1 C9400-PWR-3200AC AC 3200 W active good good good good
I Will check this PS error.
MHM
 They are in err-disable:
  Try to remove them and plug again during maintenance window.
Leo Laohoo
Post the complete output to the command "sh version".
pieterh
>>> I have 9407  core switch with 4 modules and 2 sup. We removed 1 old SUP and installed 2 new SUP, <<<
do you mean you have 3 SUP installed ? that is not correct.
Catalyst 9407R Switch
The Catalyst 9407R Switch is a seven-slot modular chassis, with two redundant supervisor module slots, five line card slots with up to 240 front panel ports, one non-redundant fan tray assembly, and a provision to accommodate up to eight power supply modules.
