9500-24 Webui Logon Help
pwiscott
Hello All,
Help ! - I have 4 9500-24 switches , have configured Gi0/0 as the management interface can ping and launch the webgui interface in a browser.
However I cannot log on ! - I have tried "cisco" and "webgui" with what I believe are the correct serial numbers in both upper and lower case.
The chassis serial numbers are from the box or whats on the chassis in the following format "CAT2424L9ZM".
I also created a local user with Level 15 privileges and set "ip http authentication local"
What am I doing wrong ?
acampbell
Try
Username cisco;
(with the semi-colon ;)
Password  CAT2424L9ZM
Regards, Alex. Please rate useful posts.
