9500 stackwise-virtual issues
campbech1
Level 5
Level 5
I have built out a new pair of 9500-40A switches with stackwise-virtual and they appeared to be running quite well with the exception that I couldn't get a neighbor for EIGRP. I just upgraded to 16.6.3 and now the stackwise-virtual command and it's configuration is gone. Anyone else having this issue?
ripbgp
Community Member
I'm running 16.8.1 - seems OK
Switch Ports Model SW Version SW Image Mode
* 1 50 C9500-40X 16.8.1a CAT9K_IOSXE INSTALL
Configuration register is 0x102
C9K_9500_CORE1_POC(config)#stackwise-virtual
Please reload the switch for Stackwise Virtual configuration to take effect
C9K_9500_CORE1_POC(config-stackwise-virtual)#
denniska1996
Frequent Visitor
Frequent Visitor
hello
i had this problem, i think your license are gone, you need to put new license on the switch and upgrade the ios
