9500 upgrade procedure
JamesAmmon8030
Being in a new position with an established team, I was following their documentation on upgrading the IOS on a set of 2 C9500 in a stackwise config.  Thankfully this was in a lab environment, I came to their step which matches the Cisco docs (linked below) to upgrade the rom-monitor capsule.
Release Notes for Cisco Catalyst 9500 Series Switches, Cisco IOS XE Cupertino 17.9.x
So I entered  "Upgrade rom-monitor capsule golden switch active r0" and let it complete.
I missed an or "upgrade rom-monitor capsule golden switch 1 r0" and I also sent this command.
That switch now only boots this far without hanging -
I'm thinking I bricked this switch, but I'm not seeing the difference in the two commands that would cause the switch not to load into ROMMON.
Leo Laohoo
Golden Capsule upgrade is not mandatory.
I do not recommend upgrading the Golden Capsule because Cisco developers do not test the firmware.  If a Golden Capsule bricks the switch, the switch will need to be RMAed.
Have a look at the attached file.  I have developed another way to upgrade a standalone and a VSS pair of 9500.
JamesAmmon8030
Thanks for your feedback, I will check through your doc/procedure.
