a log from Nexus 56128
zhiqiang.yan
I am seeing this from Nexus 56128 log, what is it :
%M2RIB-3-PIM_PIM_LIB_API_INIT: Couldn't initialize PIM-SHM-LOCK API
InayathUlla Sharieff
zhiqiang,
Could you please check if you have configured:- "logging level all 6" in your config? If it is configured then which allows this error msg to be shown.
It is not an error you have to worry about and if you configure the mrib logging to default level 2 you will not see the message anymore.
Inayath
