aaa authentication banner - showing up, with connection to aaa.
Yannick Vranckx
Level 2
Level 2
I have setup a switch with aaa authentication that is setup. I have the configuration set like this:
aaa new-model
aaa authentication banner ^CC
!!!!!!!!!!!!!!!!!! ATTENTION !!!!!!!!!!!!!!!!!!
 The ACS Server is not available at the moment
^C
aaa authentication login default group tacacs+ local
aaa authentication enable default enable
aaa authorization exec default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
With this configuration i can log-in into the switch with my aaa information/account. But i still receive the banner that the ACS is not available.
I have the same configuration on a different switch and there i do not see the banner when i login:
So this is he problem switch:
login as: user
CC
*                        UNAUTHORISED ACCESS PROHIBITED                       *
* This system is for the use of authorised users only. Individuals using this *
* computer system without authority, or in excess of their authority, are     *
* subject to having all of their activities on this system monitored and      *
* recorded by system personnel.                                               *
* In the course of monitoring individuals improperly using this system, or in *
* the course of system maintenance, the activities of authorised users may    *
* also be monitored.                                                          *
* Anyone using this system expressly consents to such monitoring and is       *
* advised that if such monitoring reveals possible evidence of criminal       *
* activity, system personnel may provide evidence of such monitoring to       *
* security officials.                                                         *
* The above notice also applies when using this system, or parts of it, to    *
* gain access to other systems.                                               *
C
Using keyboard-interactive authentication.
password:
CC
**                       UNAUTHORISED ACCESS PROHIBITED                      **
**                          YOUR SESSION IS RECORDED                         **
switch#
So i do get authenticated with the ACS server no issue, but i still receive the banner.
On a different switch with the same aaa commands i get this:
login as: user
C
password:
C
switch#
Where could this problem reside?
your 'sucess' banner should be configured with:
aaa authentication banner delimiter-string delimiter
your 'failure' banner should be configured like this:
aaa authentication fail-message delimiter-string delimiter
I would delete the banner you have currently configured and re-enter everything using the above commands...
Thanks for the response. i will configure the future configs like this.
Just weird that another switch with the same configuration does not give me this message.
