01-18-2017 05:20 AM - edited 03-08-2019 08:57 AM
Hi all,
We had 2 supervisors 720 that got defective the same time in a quad-sup VSS 6509.
Here's the current module state:
VSS#show switch virtual redundancy
My Switch Id = 1
Peer Switch Id = 2
Last switchover reason = none
Configured Redundancy Mode = sso
Operating Redundancy Mode = sso
Switch 1 Slot 5 Processor Information :
Current Software state = ACTIVE
Uptime in current state = 13 weeks, 5 hours, 33 minutes
Image Version = Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 01:30 by prod_rel_team
BOOT = sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXI5.bin,1;
Configuration register = 0x2102
Fabric State = ACTIVE
Control Plane State = ACTIVE
Switch 2 Slot 6 Processor Information :
Current Software state = STANDBY HOT (switchover target)
Uptime in current state = 13 weeks, 5 hours, 29 minutes
Control Plane State = STANDBY
Switch 1 |
Switch 2 |
Slot 5 |
ACTIVE |
Failed |
Slot 6 |
Failed |
STANDBY HOT |
I read that for replacing the defective sups, CF card from the defective sup be moved to the replacement - http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-virtual-switching-system-1440/117850-config-quadsupvss-00.html
Issue I have is defective sups has been sent back. I got the 2 replacement supervisors upgraded to the same image in production in the lab. I'm not able to test the installing of the replacement supervisors as we don't have quad sup in the lab.
My question is, do i just insert the replacement supervisors and config will be synced? What's the best way to approach this?
I'll be doing the change to install the replacement supervisor in the coming weeks.
01-18-2017 05:34 AM
you should have this already in your current config or similar
redundancy
main-cpu
auto-sync running-config
auto-sync bootvar
mode sso
Once that's there an sup is inserted and you run copy run start it should initiate a sync between the sups and bring it online ,
