04-05-2009 11:54 PM - edited 03-06-2019 05:01 AM
We have weird issue here where i am able to ping internet sites from the router but not when i give source as lan interface of router.
we have many sers effected with this they are able to access company network but not internet sites
04-05-2009 11:56 PM
Here is output ping to google.com ip
GY01-rt1#ping 74.125.93.147
Sending 5, 100-byte ICMP Echos to 74.125.93.147, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 780/784/788 ms
below is the extended ping
GY01-rt1#ping
Protocol [ip]:
Target IP address: 74.125.45.100
Repeat count [5]: 30
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: Y
Source address or interface: fastethernet0/1*************lan connection interface
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 30, 100-byte ICMP Echos to 74.125.45.100, timeout is 2 seconds:
Packet sent with a source address of 10.31.128.10
Many thanks
mahesh
04-06-2009 12:16 AM
This sounds like a NAT issue. Are you NATing your internal IPs to an internet routable address?
Please post your router configuration showing the interaces, NAT and ACLs applied.
04-06-2009 02:08 AM
Hi james,
issue is on and off.
it workks for few hours and then it stops.
I have attached router conifg.
thanks
04-06-2009 06:02 AM
Hi Mahesh,
You have several issues on this router.
1) Your IPSec configuration has an incorrect ACL. You configured for any packets sourcing from your LAN to be encrypted as it leaves the router on the WAN. You need to include just the interesting traffic on this ACL. If you need a guideline, use the ACL listed under 'NO-NAT' and the deny ACEs should be the permit ACEs under the IPSec ACL.
2) Your inside and outside interface have the 'ip nat outside|inside' commands missing.
As a side note, are you planning to have 2 IPSec Peers or just 1?
By creating a crypto map with a different name, your configuration will only allow you to have one IPSec peer.
HTH,
__
Edison.
