Able to Ping over Wan Link but not from directly connected Switch
mahesh18
Level 6
Level 6
                   Hi Everyone,
I am able to ping IP over the Wan link but not from directly connected switch.
what things i should look for on directly connected switch like ACL with ICMP allowed etc?
Mahesh
2 Accepted Solutions
John Blakley
Mahesh,
It can be many things. Is this remote from site A wan to site B wan you can ping, or do you mean that you can ping from the wan interface on the router, but the switch behind that router cannot ping?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi Mahesh,
vrf provide logical separation within the same or multiple devices.
If for example you have two customers connected to a switch or router and you don't want the customers to see each other's routes, you put each customer is a different vrf. Each vrf has its own routing table and when you ping customer a you have to use the vrf name with that ping.  If you are trying to ping customer b, you have to includes customer b vrf in that ping.
here is good doc to read:
http://www.cisco.com/en/US/docs/optical/15000r4_6/ethernet/454/guide/vrf.pdf
Reza
6 Replies 6
John Blakley
Mahesh,
HTH,
John
Hi John,
I can ping from Remote Site A to Site B  over wan link
MAhesh
Let's say that side A is the switch that can't get to the B wan link, does B know how to get back to A's inside networks or is A configured for nat? If A isn't configured with Nat, B will need a route pointing to A for any internal networks that A supports.
HTH,
John
Hi John,
I figure that ping works from Local site by using ping vrf command.
Can you  please tell me about vrf ?
mahesh
Hi Mahesh,
Reza
Hi Reza & John,
Many thanks again.
I will read about VRF  from the above link.
MAhesh
