04-11-2025 12:28 AM
I didn't find it in the data sheet, so let me ask you a question.
What are the supported connection speeds for the 10GBase-T ports on the C1300-16XTS?
I don't have a description, so I feel like it's not a multi-giga.
I want to know if 100M and 1G are supported in addition to 10G.
※ Some distributors may describe it as Multigiga.
Some are listed as 10GBase-T, so it is confusing in various places.
If possible, it would be very helpful to introduce evidence materials as well.
Thank you very much.
Solved! Go to Solution.
04-11-2025 06:05 AM
The document "Port Type" below is applicable, and it seems to be different for each port type.
Note: This is the information that was checked on a document-based basis because I don't have an actual device.
Catalyst 1300 Admin Guide - Port Management [Cisco Catalyst 1300 Series Switches] - Cisco
https://www.cisco.com/c/en/us/td/docs/switches/campus-lan-switches-access/Catalyst-1200-and-1300-Switches/Admin-Guide/catalyst-1300-admin-guide/port-management.html
> Displays the port type and speed. The possible options are:
> Copper Ports—Regular, not Combo, support the following values: 10M, 100M, 1000M, 2500M (type: Copper) and 10G.
> Combo Ports—Combo port that is connected with either copper CAT6a cable or SFP Fiber Gigabit Interface
> 10G-Fiber Optics—Ports with speed of either 1G or 10G
04-11-2025 01:49 AM
Hello
04-11-2025 01:51 AM
04-11-2025 06:05 AM
04-11-2025 07:00 AM
MyHomeNWLab
Thank you very much for your professor.
Since the C1300-16XTS metal 10G port is not a combo, the following applies:
I understand that 10M, 100M, 1G, 2.5G, and 10G support speeds.
We appreciate your presentation of evidence!
04-11-2025 07:26 AM
You're correct, datasheet doesn't make clear the capabilities of their copper 10g ports.
I doubt they are full mgig ports, as that's a feature often touted.
As the fiber ports are SFP+, they should support gig and 10g. So, if the copper ports are multi speed, at all, they too might be gig/10g.
Have you tried contacting Cisco sales?
04-11-2025 07:27 AM
