Showing results forĀ
Search instead forĀ
Did you mean:Ā
about a SFP port
MusNexus
Can someone tell me if we can add a SFP port of Ten Gigabit on the 2960S-48LPS-L switch ? if no, is there a solution to have a Ten Gigabit for that swith
thank you
Reza Sharifi
That is not possible.  The SFP ports on that model are 1Gig and cannot be upgraded to 10Gig.
You need a different switch that supports 10Gig.
Have a look at the 2960x data sheet:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/data_sheet_c78-728232.html
