access control list problem
fran19422
Level 3
Level 3
Hello, I am trying to deifne an access control list to permit traffic from all internal (172,16.0.0/16) addressess, and deny all other traffic.
I have created the following:
access-list 1 permit 172.16.0.0 0.0.255.255
access-list 1 deny any
and applied it to the outgoing interface of the router:
interface FastEthernet0/0
ip address 10.0.0.1 255.0.0.0
ip access-group 1 out
ip nat outside
duplex auto
speed auto
However traffic from the networks: 172.16.4.0, 172.16.3.252, 172.16.255.252 and 172.16.255.248 cannot pass.
Have I done something incorrect here ?
Thanks for any help.
3 Accepted Solutions
canalc
Community Member
hi philip:
     traffic from the networks: 172.16.4.0, 172.16.3.252, 172.16.255.252 and 172.16.255.248 is be nat ip 192.168.1.6
    192.168.1.6 can not pass the
Why are you doing this NAT overload on Belfast ?
Just  do no ip nat outside on Belfast f0/0 so there ain't no more NAT and it will work.
Regards.
Alain
Hi Alain,
Thanks for lending a hand on OP's issue!
Philip,
Could you try what Alain suggested and let us know how it goes?
7 Replies 7
johnlloyd_13
Level 11
Level 11
hi philip,
could you post the device's show run and a network diagram? are you running this on PT?
thank you for your help.
I have attached the packet tracer file. It should be easy to see what I am doing wrong for someone more proficient than me
The two passwords are:'cisco' and 'class'.
The router with the access control list is "Belfast".
hi philip,
sorry i don't have PT installed on my PC right now. could you copy and pase the config here?
yes, I have done that in the previous message.
Thank you kindly.
Regards.
Alain
Hi Alain,
Philip,
canalc
Community Member
hi philip:
