NAT translation timeout in Packet Tracer ?
fran19422
Hello, is there any way to set this in Packet tracer.
I have been using the standard 'ip nat translation timeout' command but it does not work.
Thanks for any help.
5 Replies 5
johnlloyd_13
Level 9
Level 9
hi philip,
PT device IOS capabilities are limited. try using GNS3 (or real gear) instead.
thank you for your help.
So is that a confirmation that this command or a variation on it is not available in Packet Tracer ?
Thanks,.
hi philip,
what options do you get in PT when you issue this command under global config mode?
ip nat translation ?
i've removed PT on my PC so i can't confirm right now.
I can only get as far as:
Belfast(config)#ip nat ?
  inside   Inside address translation
  outside  Outside address translation
  pool     Define pool of addresses
Thanks.
Hi Philip,
I'm sorry to say the command isn't an option or available due to PT/IOS's constraint.
