Access Level Switch uplink?
TM13
Level 4
Level 4
We looking 4510E for the Access level area, but when starting to use Wave2 APs on end user ports then how to solve the 10Gb uplink issue? We probably install like 40-60 APs...
neelesh.gaekwad
Level 2
Level 2
order the Ethernet card with multigigabit Ethernet supported port : WS-X4748-12X48U+E which is having 12 numbers of multigigabit ports. connect your access point to one of these port. I will give you more than 1G speed and upto 5-8G speed
neelesh.gaekwad
Level 2
Level 2
