Access points connect to wrong WLC
Hello everybody,
I have a problem with some access point.
We have two WLC's one AIR-CT5508-K9 and one AIR-WLC4404-100-K9.
now i have 6 access points that don't register anymore to the right controller.
in high availability i have set the right name of primary controller and also the correct ip address, but somehow they keep registering to the other controller.
Does someone know how i can fix this problem.
info:
AIR-CT5508:SEDA-PM_Line_1
WLC4404: SEDA-PM_Office_1
6 accesspoints are connected to SEDA-PM_Line_1 but they should be connected to SEDA-PM_Office_1
settings in AP are correct in my opinion
6 Replies 6
jamescox3
If you can connect a console cable to one of the AP's in question, power it off and back on, watch the CLI to which WLC it is trying to associate with at boot up.
I had a similar issue when I added 802.11n access points for the 1st time, turned out they were looking for a different DNS entry to find the WLC.
Leo Laohoo
Can you please post the output to the following commands:
1.  4400 WLC:  sh sysinfo;
2.  4400 WLC:  sh time
3.  AP:  sh version;
4.  AP:  sh ip interface brief; and
5.  AP:  sh inventory
here is the information,
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.116.0
RTOS Version..................................... 7.0.116.0
Bootloader Version............................... 3.2.195.10
Emergency Image Version.......................... N/A
Build Type....................................... DATA + WPS
System Name...................................... SEDA-PM_Office_1
System Location.................................. Mao, Brazil
System Contact................................... Network_Admin
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.3
IP Address....................................... 105.103.112.5
System Up Time................................... 8 days 15 hrs 9 mins 55 secs
System Timezone Location.........................
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +38 C
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 13
Number of Active Clients......................... 132
Burned-in MAC Address............................ 00:22:55:91:2B:C0
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Absent
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 100
(Cisco Controller) >show time
Time............................................. Thu Jan  9 07:58:29 2014
Timezone delta................................... -4:0
Timezone location................................
NTP Servers
    NTP Polling Interval.........................     86400
     Index     NTP Key Index     NTP Server      NTP Msg Auth Status
       1              0        211.189.10.2       AUTH DISABLED
AP information
Warehouse_AP-3#sh version
Cisco IOS Software, C1240 Software (C1240-K9W8-M), Version 12.4(23c)JA2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 13-Apr-11 12:58 by prod_rel_team
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
Warehouse_AP-3 uptime is 18 hours, 16 minutes
System image file is "flash:/c1240-k9w8-mx.124-23c.JA2/c1240-k9w8-mx.124-23c.JA2"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1242AG-A-K9   (PowerPCElvis) processor (revision A0) with 27638K/5120K bytes of memory.
Processor board ID FTX1233B943
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 7.0.116.0
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1D:70:96:64:A0
Part Number                          : 73-9925-07
PCA Assembly Number                  : 800-26579-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC12320AKT
Top Assembly Part Number             : 800-29151-03
Top Assembly Serial Number           : FTX1233B943
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1242AG-A-K9
Configuration register is 0xF
Warehouse_AP-3#sh ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
Dot11Radio0                unassigned      NO  unset  up                    up
Dot11Radio1                unassigned      NO  unset  administratively down down
FastEthernet0              105.103.27.19   YES other  up                    up
Warehouse_AP-3#sh inventory
NAME: "AP1240", DESCR: "Cisco Aironet 1240 Series (IEEE 802.11a/g) Access Point"
PID: AIR-LAP1242AG-A-K9, VID: V03, SN: FTX1233B943
there are 7 AP's that not register to the right controller some are different models:
Warehouse_AP-1 - AIR-LAP1242G-A-K9
Warehouse_AP-3 - AIR-LAP1242AG-A-K9
Warehouse_AP-5 - AIR-LAP1242G-A-K9
Warehouse_AP-6 - AIR-LAP1242G-A-K9
Warehouse_AP-7 - AIR-CAP3502I-T-K9
Warehouse_AP-9 - AIR-LAP1242AG-A-K9
Warehouse_AP-10 - AIR-LAP1242G-A-K9
Thank you for your help!!
Looks like everything is right, except the 3500 which has a regulatory domain of "-T".
Can you confirm that the APs have the correct "Primary" controller settings?
Sent from Cisco Technical Support Wii App
All AP's are set to SEDA-PM_Office_1 with ip address 105.103.112.5
Warehouse_AP-3# lwapp ap primary-base SEDA-PM_Office_1
Warehouse_AP-3#lwapp ap contr
Warehouse_AP-3#lwapp ap controller ip address 105.103.112.5
i will try to reload the controller in lunch time, maybe the AP's will rejoin the right controller then.
The AP,s i have already reset some times, but no effect.
If someone have any other suggestions please let me know!
Maybe some additional information.
After reboot both WLC's some access points returned to the correct controller.
the only strange thing is that the controller only accept 48 access points, before reboot was 48 as well.
only now some accesspoints changed from WLC.
we have license for 100.
"Maximum number of APs supported                   100"
Please someone have an answer ?!
Thanks for your time
