Access port connection
gurkamal01
This is collapsed core design.
I have 3550  which has  a Gig access link connection   to core switch 2(6513) on vlan253.
It also has another access-link connection  to a 3524 switch on vlan 230.
3550 switch has ip address as 192.168.253.13 and default gateway 192.168.253.1 (core 2)  and no SVI for vlan230.
I am trying to connect a host on 3550 swi in vlan 30 with static ip address and see port UP and UP  but no connectevity.
Q1. On my host i am using a default gateway as 192.168.230.1. Is this a problem. if not what can be the problem?
Core 2 has route to 192.168.230.0 network. Core 2 does not any SVI for 230
I have noticed my network has lot of access link connection between switches and not trunks
Q2.What effect does this make?
Please advice
19 Replies 19
On you host connected to the 3550 using static IP, what is the IP (is it in the 192.168.230.x range and the same mask as the default gateway 192.168.230.1?) Also, which device is 192.168.230.1? This will tell us if there's any problem.
Having access links between switches instead of trunks have a difference that only a single VLAN can pass through that link.
Is this correct with your scenario?
Federico.
Thanks for the reply,
Host has an ip of 192.168.230.x and vlan 230 exist on th 3550 switch
port connected to host is in vlan 230
Host ---->3550(No SVi for vlan230) ------> 3524(NO SVI for valn 230)-------> 3750(192.168.230.5) --------> content service switch
I am sorry the default gateway on host is 192.168.230.5
Leo Laohoo
Is the port configured for VLAN 230?  Is VLAN 230 existing in the VLAN Database of the 3500XL?
Jon Marshall
Please advice
Just to try and clarify exactly what is happening in your network, the difference between using access ports and trunks between switches -
(Leo / Federico - apologies if this seems a bit off topic but this is kind of a continuation of a couple of other posts so i'm just concentrating on Q2)
  SW1   <--- VLAN 253 ----> SW2
SW1 has vlan 10
SW2 has vlan 11
for any clients in vlan 10 to communicate with clients in vlan 11 you would need to route them across the vlan 253 link.
SW1 would need a L3 SVI for vlan 10 and a L3 SVI for vlan 253
SW2 would need a L3 SVI for vlan 11 and a L3 SVI for vlan 253
HI is in vlan 10
H2 is in vlan 11
H1 sends a packet to it's default-gateway which is the IP address of SVI for vlan 10. SW1 then routes the packet to vlan 253 and the packet is switched across the vlan 253 interconnect. When it arrives at SW2, SW2 routes the packet onto vlan 11 and to H2.
Now, if you wanted to put a host on SW1 into vlan 11 you can't do this because the 2 switches are separated by a different vlan. The key thing is with the above setup vlan 10 is isolated to SW1 and vlan 11 is isolated to SW2.
To understand exactly why it's important to understand how packets are switched/routed. Lets say we add another host
H3 is in vlan 10 but on SW2
So H1 wants to send a packet to H3. H1 knows it's own network by comparing it's IP address with it's subnet mask -
H1 = 192.168.5.10 255.255.255.0  so H1 knows it's subnet is 192.168.5.0
H3 has an IP of 192.168.5.12
H1 compares H3s IP with it's own subnet mask (it only knows it's own subnet mask) -  192.168.5.12 255.255.255.0 so H1 knows H3 is also on the 192.168.5.0 subnet.
Because they are on the same subnet the packet cannot be routed, it has to be switched. And the only way the packet could be L2 switched is either -
1) the interconnect between the 2 switches would have to be in vlan 10
or
2) the interconnect would have to be a trunk
SW1  <--- trunk ----> SW2
SW1 has vlan 10
SW2 has vlan 11
vlan 10 & 11 are allowed on the trunk
In the above setup you can put a host in vlan 10 on either switch and it will be able to communicate with a host in vlan 10 on the other switch. As for the SVIs, you can put both SVIs on SW1 or SW2 and it will work fine. The vlans are not isolated to each switch, they can be on both switches if that is what you want.
So in answer to your question, using access ports on interconnects isolates vlans on either side of the links that are not part of the vlan that you use to interconnect the switches. You cannot have the same L2 vlan on either side of the interconnect.
This is basically what it is happening in your network. You need to fully understand this so you can troubleshoot why you are having connectivity problems.
Jon
Please advice
I have added all the config files for the interconnected switch
Host ----> 3550------> 3524-------> 3750--------> Content service switch
please advice how can fix this problem
Configure SVI in 3750 and make this as default gateway for vlan 230 in which host is connected and in switches 3550 and 3524 cofnigure trunk ports and also configure default-network command towards 3750 Vlan 230 SVI.
Check out the belwo link to configure trunk port in switches
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010f615.shtml
Hope to help !!
If helpful do rate the post
Ganesh.H
3750 has a default gateway of 192.168.230.1
how will it help by having SVI for vlan230 on 3750.
i already have access port connections in vlan 230 going from 3550 to 3524 and also another access port in vlan230 going to 3750
I believe i only need a trunk if i need to carry multiple vlans
3750 has uplink connection to a cisco content service switch (11500).
please advice
Hello
Please advice
Actually there is lots of confusion with above post which post is true i would go with the lates one
Host is connected in 3550 vlan 230 and gateway is configured as 192.168.230.5 what is this ip address is this SVI configured in 3750 switch for vlan 230 or something else ?
If SVI for vlan 230 then configure ip default-network command in 3550 and 3524 switches towards 192.168.230.5 and then check are you able to ping this ip or not 192.168.230.5
Hope to help
Ganesh.H
  I am sorry about the confusion
192.168.230.5 is ip adress of 3750
Q1 what should i use as deafult gateway on my host?
Q2 should i go ahead and put a default network command on 3550 and 3524?
Please Advice
Please Advice
The problem is your connectivty in switch 3524 with 3550 and 3750,The port which are connected with 3550 and 3750 with 3524 are in different vlan that is in vlan 21 configured in switch 3524 port 0/1 and 0/2.
So change the port to vlan 230 and make a host default gateway as 3750 switch ip 192.168.230.5 and then check are you able to ping or not.
Hope to help
Ganesh.H
HI
I am sorry but i checked gi0/1and gi0/2 are in vlan 230
I edited the config file of 3524 and by mistake deleted the Gig word
we can verify that in the config of 3550  as remote interface in cdp command
! can ping 192.168.230.5(3750) from 3550
when i do traceroute from 3550 it goes to core 2 swi (192.168.230.1)and then to  another switch and completes.
Is this because 3550 has default gateway of 192.168.230.1.
please advice
HI
please advice
But the config files which you have uploaded it shows the ports are in vlan 21 which are connected to switch 3550 and 3750 and 3550 config file is havin a default gateway towards the ip default-gateway 192.168.253.1 in the uploaded file.
and for your query yes if default gateway is configured as 192.168.230.1 in 3550 which is the vlan 230 ip subnet as per the config file then it will land on to core 2 and then to switch 3750 switch SVI interface ip address 192.168.230.5, Hope that clear !!
Anyhow i would recommend you to have clear cut understanding of your network flow so that in future you wont have trouble to understand the traffic flow in your network and always whenever you do changes just note down the changes what ever yo have done on the switches or take complete backup of switches before doing any change in live network.
Hope to help !!
Ganesh.H
the default gateway on 3550 is 192.168.253.1(core 2) and not 192.168.230.1 (my fault agian)
so how can i fix this problem
I have access connection of vlan 253 from 3550 to core 2
and another access connection of vlan 230 to 3524 SWI
Traceroute 192.168.230.5 first hits core 2 and goes ahead to destination
3550 does not have SVI for vlan 230 and nor does Core 2?
on core 2 i do see a route of 192.168.230.0(ospf) via vlan 253 when i do a show ip route
please advice
