08-12-2008 09:47 AM - edited 03-06-2019 12:45 AM
I'm trying to mapp out a network and I have a catalyst switch I need to access. The only information I have is that it is not ip addressed. It is accessed through port 49 VL220 I have the password but don't know how to interface with it with out a ip. I could use a consul cable but have been told I should be a to access through the port using ethernet
08-12-2008 10:04 AM
If it doesn't have an IP address then you can't manage it by telnet. You'll have to console into it.
08-12-2008 10:15 AM
Yes, without IP no telnet.
If you are not sure, you can check if he really have no IP , but only if cdp is enable.
"show cdp neighbors detail"
