Accessing the management interface remotely on a L3 switch *tricky*
SJ K
Level 5
Level 5
I am setting up a new 2960XR switch (with ip routing on) and I have several questions which I hope the wonderful folks here can shed some advice on
q1) can a management interface/ip on FE0 (fa0/1 in picture below) be access remotely from another network ?
(e.g. Assume all routing is setup properly in the routers - can my PC at 192.168.0.1 access the Management interface of Switch 1 at 192.168.8.2)
q2) if the answer the above is a Yes, and since my 2960XR is a L3 switch, does that means I need to create a static route in Switch1
ip route 192.168.0.0 255.255.255.0 192.168.8.1 ? --> and traffic to the management port will return via the port itself to router0 at 192.168.8.1 ?
q3) if the answer above is a Yes, consider the below diagram where Router0 has a new connection from Fa0/1 to Fa0/2 at the switch0 depicted by the thick black arrow and the network between them is 192.168.9.0/24.
Fa0/2 of Switch1 is configured as part of Vlan9 and Vlan9 is setup with an SVI -192.168.9.2.  End devices connected to switch1 on Vlan9 has their gateway set to point to the SVI at 192.168.9.2.
Now bearing in mind the static route created earlier
ip route 192.168.0.0 255.255.255.0 192.168.8.1 (set for the return traffic for traffic to the management interface)
If PC0 were to access a device in VLAN9 (e.g. 192.168.9.10) and 192.168.9.10 has its gateway set at the VLAN9 svi 192.168.9.2,  the return traffic from 192.168.9.10 to 192.168.0.1 (PC0)  will be stuck at switch1 isn't it ?
pc0 (192.168.0.1) -> deviceatV9 (192.168.9.10)
deviceatV9 (192.168.9.10) ---> vlan9SVI at Switch1 (192.168.9.2) ---> switch1 has a route to 192.168.0.0 through its management interface
*but the management interface cannot be use to route other traffic through it
If i change the earlier route for the return traffic to 192.168.0.0 to
ip route 192.168.0.0 255.255.255.0 192.168.9.1
If i access the switch management ip 192.168.8.2 from PC0, can the return traffic from the management interface go through the normal network port at VLAN9 via the above route ? -- seems like a no also
From the doc -> The switch cannot route packets from the Ethernet management port to a network port, and the reverse.
How do i make traffic originating from PC0 to go via management route it is accessing management ip and go via the vlan9 network route if it is accessing vlan 9 ?
Noob
8 Replies 8
Hello SJ K,
New Cisco Routers and Switches come with a dedicated Ethernet port which unique purpose is to provide management access to the device via SSH or Telnet.
Usually, that interface is isolated in its own VRF called "Mgmt-intf'. That means the static default route should not interfere with Routing in the Global Routing Table or any other VRF configured, that mangement traffic is isolated in its own VRF. The configuration for the Management Interface cannot be modified in terms of VRF, you can only assign an IP address to it and a Static Default Route to allow connectivity.
The purpose is to connect that interface to an isolated IP network that can guarantee "always on" access to the device only for management purposes.
However, it is not a must to use that interface for management. You can still configure your device to accept SSH and Telnet sessions on the Global Routing Table or any other VRF (in other words, coming from any other interface).
Here some information about Management Interface.
I hope this helps.
Best Regards.
Hi Hector,
I am glad you replied.
I am using a cisco 2960X and 2960XR switches,  does the management interface comes with its own routing table ?  (how do i check ?)
It seems like the management interface and the other network interfaces are sharing 1 routing table though.
Noob
Let's check the interface's configuration and the VRF table:
  • show running-config interface FastEthernet0
  • show vrf brief
In the case the Management interface is sharing the Global Routing Table, I would recommend to manually isolate it in its own VRF (is possible).
Best Regards.
Hi Hector
 description Mgmt
 ip address 192.168.6.99 255.255.255.0
end
There is no "show vrf "  command.
I am on Cisco 2960X and Cisco2960XR. How do I isolate it in its own VRF ?
Noob
Try with:
ip vrf mgmt
int Fa0
 ip vrf forwarding mgmt
Best Regards.
Having similar issue
Hi Hector,
DSW#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
DSW(config)#ip vrf ?
% Unrecognized command
DSW(config)#int fa0
DSW(config-if)#ip vrf ?
The ip vrf command are not recognised.  Do you want me to forcefully load it in the config ?
Noob
doubt you're running the correct version of code (IP LAN/Base), VRF config is only support on => IP Services.
