PBR on SVI
rasmus.elmholt
Level 7
Level 7
I om trying to configure PBR on a SVI interface but I cannot activate the configuration.
VLAN100(config)#int vlan 100
VLAN100(config-if)#ip policy route-map vlan100-in
VLAN100(config-if)#do show run int vlan 100
Building configuration...
Current configuration : 62 bytes
interface Vlan100
ip address 10.0.100.1 255.255.255.0
end
It does not give any errors.
SW: c3560-ipservicesk9-mz.150-2
Mark Malone
2 things for pbr on 3560 to work required
1 You need an ipservices license -- check your show license
2 Your sdm must be set to routing --show SDM prefer
Mark Malone
Thanks, totally forgot about the SDM template and PBR support.
VLAN100#show lice
% Invalid input detected at '^' marker.
VLAN100#show sdm pref
The current template is "desktop default" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 6K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 8K
number of directly-connected IPv4 hosts: 6K
number of indirect IPv4 routes: 2K
number of IPv6 multicast groups: 0
number of IPv6 unicast routes: 0
number of directly-connected IPv6 addresses: 0
number of indirect IPv6 unicast routes: 0
number of IPv4 policy based routing aces: 0
number of IPv4/MAC qos aces: 0.5K
number of IPv4/MAC security aces: 1K
number of IPv6 policy based routing aces: 0
number of IPv6 qos aces: 20
number of IPv6 security aces: 25
VLAN100#
