ACE 10 Configuration
jfraasch
Level 3
Level 3
I am going to install two 6513's. Each will have the ACE-10 module. Is it difficult to set up active passive between the two?
James
Reza Sharifi
Hi James,
Are you trying to use the ACE module for load balancing?
Reza
Just read the white paper on this.
But yes, going to use them in active/active mode across the 6513's.
Seems pretty complicated to set up. The 6513 has a FWSM installed as well. This seems to be what I want (this was all bought before I got here-I just started on Monday).
But it is cool that I can run these in Active/Active mode. Now I just have to figure out how the heck to configure the way I want them.
Nothing like having someone blow $1 million bucks and not know what to do with it! I have 4 of the 6513s that will be set up in primary and backup data centers. Gonna be hard. But gonna be fun, too!
