IRDP
jfraasch
Level 3
Level 3
I get how to configure on a router and what it does. But what does one need on a workstation in order to get the IRDP pakcets and find the router? I dont see it as part of my normal IP stack on my NIC.
Thanks.
James
Giuseppe Larosa
Hello James,
it looks like it is disabled by default on recent windows versions.
see the following it shows a registry entry to check
http://www.unifiedcompliance.com/matrices/live/01799.html
Hope to help
Giuseppe
Giuseppe Larosa
Hello James,
Hope to help
Giuseppe
You are correct.
Must make a new registry entry into the PC to re-enable. Thanks for the link.
James
