ACE + FWSM failover - 2 chassis
I'm running 2 6509 Chassis - in each chassis there is a FWSM module in routed mode, ACE in bridged mode, trunks between the 2 chassis for FT, State and also Data.
When I fail a single context from Chassis 1 to Chassis 2, there is a 6 second delay before traffic resumes, it is pretty much instant on the fail back.
Is this normal? There is an outstanding bug relating to failing BACK, but this is in the other direction, so I am a ittle confused.
Normal,or something I can fix?
Cheers
Graeme.
wong34539
Level 6
Level 6
Post your device show tech
