Hi, I have a cisco 2960 as the commander switch with an ip address that is reachable on vlan10 'I had to change the cluster management vlan to 10'. The other 4 switches are 2050's, and are all in a cluster.
When I try using the CNA cluster conversion wizard, I get a 'failed to connect'. My best guess is that the rest of the switches are using vlan 1 as the management cluster vlan?
Any suggestions appreciated
jason.
