ACE Module IOS Upgrade
Elie Bassil
Level 2
Level 2
We have a scenario of two ACE20-MOD-K9 installed on two core switch WS-C6513 (active/standby). They are currently running on A2(1.1a). We need to upgrade them to A5(1.2).
I was checking Cisco documentation but so far couldn't find any relevant document that targets the below issues:
_is there IOS upgrade path we need to follow before reaching A5(1.2)?
_do the configuration change between A2 and A5?
_any minimum core switch IOS to support A5(1.2)?
_any specific steps for active/standby scenario we need to follow?
Appreciate if someone can shed some light.
regards,
E.B:.
Amit Singh
Hi Elie,
Did you have a look a the release notes for A5(1.x) for the above concern?
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA5_1_x/release/note/ACE_mod_rn_A51x.html
Hope this helps.
Cheers,
-amit singh
