ACL & Wildcard Question!
Iluvnetwork
If I want to allow 192.168.1.0/24 and 10.178.5.0/24, but deny 172.224.4.0/24 in one ACL, how should I do?
Everything depends how specific you want to be, I hope that it is understood that
permit ip 0.160.1.0 219.26.4.255
will permit way much more networks than just 192.168.1.0/24 and 10.178.5.0/24 and block way much more than just 172.224.4.0/24.
In first octet 0 with wildcard mask 219 permits networks having 1, 2, 3 in the first octet, however, it will block any network that starts with 4 in the first octet etc... Generally, depending on how specific you want to be - depends list of potential solutions. For example, blocking of 172.224.4.0/24 can be also done with permitting 0.0.1.0 255.255.254.255 but it will block way much less networks than your original statement since it will just permit any network that has odd number in 3rd octet. Also, there are many other solutions there...
So, question is how specific you want to be with your solution - what exactly should be block and what exactly can be permitted..
11 Replies 11
Seb Rupik
ip access-list standard SIMPLE
  permit ip 192.168.1.0 0.0.0.255
  permit ip 10.178.5.0 0.0.0.255
The deny is implicit.
cheers,
Seb.
My bad. I meant one ACL line.
I got this permit 0.162.0.0 219.26.4.255
Hello
Do you mean one acl and just one ACE? If so then it cannot be done, you will need at least two ace with one ACL to complete this.
res
Paul
Kind Regards
Paul
My final answer is 0.160.1.0 219.26.4.255. By permitting this, I can allow 192.168.1.0/24 and 10.178.5.0/24, and block 172.224.4.0/24.
If I am misunderstanding about "Wildcard Mask", please let me know.
Hello
That acl  statement makes no sense?
As I stated previously you cannot create an access-list  permit/deny with two different subnets with just one access list control entry (ace) in a single access-list
res
Paul
Kind Regards
Paul
EDIT: After some more thinking about it ... No, my solution doesn't work ... Damn, I was calculating this stuff some years ago but I don't get it any more ...
Are you preparing for your CCIE-exam? Paul, if yes, then it doesn't have to make any sense, its just about binary math ...
My solution is "permit 0.160.1.0 202.26.4.255". But with a severe cold I'm far away from clear thinking ...
Lets look at it:
11000000.10101000.00000001.00000000 = 192.168.1.0
00001010.10110010.00000101.00000000 = 10.178.5.0
we use a "0" if we don't care about the digit and we us the digit if we care (first line). A "1" for every "don't care" in the second line:
00000000.10100000.00000001.00000000
11001010.00011010.00000100.11111111
The first line gives the address, the second line the wildcard-mask.
Hello
@Karsten Iwen wrote:
EDIT: After some more thinking about it ... No, my solution doesn't work ... **bleep**, I was calculating this stuff some years ago but I don't get it any more ...
Lets look at it:
Intact I am Karsten - for a while now- I just haven’t got the balls to take that jump and sit the lab!!!-
I am also aware of the binary conversion -So I will reiterate why to me it doesn’t make any sense -  where in that acl does it negate just the 172.x.x.x as far as I can see it denys everything
I may be mistakenl here but wasnt  the OP stating to permit just those two hosts and then deny just that 172. Host And if that is the  case then it cannot be done with just one acl and one ace as far as I am aware?
res
paul
Kind Regards
Paul
I don't even have a CCNA cert. I recently learend about the wildcard mask and thought it would be fun to play with it. As I said, my answer is 0.160.1.0 219.26.4.255 which allows 192.168.1.0/24 and 10.178.5.0/24 and blocks 172.224.4.0/24. I guessed your ACL only allows 192.168.1.0/24 and 10.178.5.0/24 because at the end of ACL, it denys any :) Thank you very much :)
Thank you so much. This is what I have been wondering :) Learned a lot from your comment.
My new answer is 0.168.1.0 202.26.254.255 -> Is this one better than my previous answer which was 0.160.1.0 219.26.4.255?
As you already mentioned, I agree blocking 0.0.1.0 255.255.254.255 is the best answer :)
