Acl-copp-management
D@1984
can someone please advise why I need line 4 of below Acl? I understand we use established when we want to allow the response to the connection initiated from the internal network but on line 3 we allow ssh from any source to any destination already. So why we still need line 4?
thanks
ip access-list extended acl-copp
permit udp any any ntp
permit udp any any snmp
permit tcp any any eq 22
permit tcp any eq 22 any establishe
Giuseppe Larosa
Hello D@1984 ,
in the ACL line 3 is for the incoming SSH sessions and it allows them.
Line 4 allows outgoing SSH sessions started from the local system to some other system (any) .
The two lines perform different duties. The key difference is that in line 3 the TCP port for SSH is matched as a destination port, and in line 4 TCP port 22 SSH is matched as source port.
The well known port is on the server side.
Hope to help
Giuseppe
Any source to any destiantion IP but any l4 port to ssh l4 port
That why we need line 4 which specify any IP l4 port ssh to any IP any l4 port
MHM
Giuseppe Larosa
Hello D@1984 ,
Hope to help
Giuseppe
