ACL Hardware Resource Utilization on Nexus 7700
afsharmilad89
I need help to understand the exact meaning of "Mac Etype/Proto CAM" in my show hardware capacity forwarding command on Nexus 7700? there are 11 in used but I don't know what are they? The picture of my show command is attached.
To see the table of EtherType entries in the EtherType/Proto TCAM region, you would need to execute the show commands from the default VDC - currently, you are in VDC-2.
You can consider the values shown for the EtherType/Proto TCAM region as informative, and you do not need to be concerned about them as long as you do not intend to specify additional non-IP protocols in your CoPP policies.
Best regards,
Peter
Peter Paluch
One of the ways to see what entries are being stored in the EtherType/Proto TCAM region is to use the show hardware access-list resource entries detail command; another command where the same information is displayed would be show hardware access-list input entries. For example:
N7K# show hardware access-list resource entries detail module 1
[ ... cut ... ]
Index  Mac - Etype Proto  ref_count
  11           35092 0      1
  10           35078 0      1
  9            34880 0      1
  8            13313 0      1
  7            34883 0      1
  6            34825 0      1
  5            35136 0      6
  4            34958 0      1
  3            34824 0      1
  2            35061 0      1
  1            35020 0      1
11 mac protocol cam entries are in use
[ ... cut ... ]
Numbers shown in this output are in decimal; converting them to hexa values would produce the following table of protocols:
11 35092 0x8914 FIP Storage Access Protocol
10 35078 0x8906 FCoE
9 34880 0x8840 L2Tunnel across vPC peer-link (BPDUs etc.)
8 13313 0x3401 SDP/SRP
7 34883 0x8843 Cisco Fabric Services over Ethernet (used with vPC)
6 34825 0x8809 LACP
5 35136 0x8940 ECP
4 34958 0x888E 802.1X
3 34824 0x8808 Flow Control
2 35061 0x88F5 MVRP
1 35020 0x88CC LLDP
You would see references to these protocol types in the show hardware access-list input entries detail output, mostly in CoPP entries (if sifting through this output, search again for decimal values).
Best regards,
Peter
Hello again and thanks for your quick response, I would like to know that is it essential to care about this used number(Mac Etype/Proto CAM       11(Used)      3(Free)       78.57(Percent) ) and is it vital or is just for informing ? also the out put of show hardware access-list input entries detail is shown as below:
slot 3
NOT Supported in SUP ACLQOS
slot 4
slot 5
Flags: F - Fragment entry E - Port Expansion
D - DSCP Expansion M - ACL Expansion
T - Cross Feature Merge Expansion
VLAN 689 :
INSTANCE 0x0
Tcam 1 resource usage:
Label_b = 0x201
Bank 0
IPv4 Class
Policies: PBR(Firewall) [Merged]
Netflow profile: 0
Netflow deny profile: 0
Entries:
[Index] Entry [Stats]
[001d:0013:0013] prec 1 permit-routed ip 0.0.0.0/0 224.0.0.0/4 [0]
[001e:0014:0014] prec 1 redirect(0x66)-routed icmp 0.0.0.0/0 0.0.0.0/0 [27471381]
[001f:0015:0015] prec 1 redirect(0x66)-routed udp 0.0.0.0/0 0.0.0.0/0 [1129285680]
[0020:0016:0016] prec 1 permit-routed ip 0.0.0.0/0 0.0.0.0/0 [187549187703]
L4 protocol cam entries usage: none
No mac protocol cam entries are in use
VDC-2 port-channel2 :
no acl related hardware resources found
VDC-2 port-channel9 :
VDC-2 Ethernet5/4 :
VDC-2 UF-All Ports in VDC 2 :
Best regards,
Peter
