ACL is not blocking traffic between VLANs
ALIAOF_
Level 6
Level 6
I am trying to block traffic from one VLAN to other VLAN's and even  after applying an ACL with "deny ip any any" traffic is still going  through.  Here is my config:
Note:  Both switches are setup in a GLBP configuration
Access List:
ip access-list extended VLAN120_IN
deny ip 10.1.120.0 0.0.0.255 any
Switch 1:
interface vlan 120
ip access-group VLAN120_IN in
Switch 2:
interface vlan 120
Now  when I do a ping to my own laptop and source it from vlan 120 like  this, "ping 10.1.136.72 source vlan 120" I get successful replies.  Any  idea what am I missing here?  Thank you
Note:  I even tried VLAN ACL setup same results.  I can ping the host from one switch(the one that is AVF) but not the the other.
pille1234
Level 3
Level 3
Hallo
That is expected behaviour. The ACL works only for traffic going through the switch, not for switch generated traffic. Try to ping the gateway from a host in vlan 120 and you will get a dest. unreachable message.
Pinging int vlan 120 from outside vlan 120 on the other hand will show you a successful answer.
6 Replies 6
Reza Sharifi
If you are trying to block traffic from one vlan to another, try your access-group outbound and test again.
I'm trying to block traffic from VLAN120 to other VLAN's.  So I applied the access-group in as that is supposed to be the traffic from the hosts on the 120VLAN to other VLAN's or is that wrong?
what is your Vlan 120 Ip adress range configured
VLAN 120 IP range is 10.1.120.0/24
pille1234
Level 3
Level 3
Hallo
Thank you that was it .
