ACL is not working as expected
bssangeeth
Hi Everyone,
I have an internet router which is having a server farm switch connected to its fa0/0 port and in fa0/1 is going to ISP. We are using public IPs in both servers and router interfaces. My requirement is to deny unwanted traffic coming from outside network to my servers at the same time, servers in other location need to communicate with my inside servers.
But the problem which i am facing here is, after creating ACL i have placed it as an inbond ACL in fa0/1. The outside to inside traffics are getting blocked as desired, but all my server farm servers are not able to access internet.
If i give ESTABLISHED in ACL, the session which is already open for internet will works fine. But if we close and reopen the browser, then we will not be able to access the internet.
Suppose below are my IP schema.
R1 fa0/1 – 192.168.1.62/30; ISP Gateway – 192.168.1.61/30
R1 fa0/0 – 192.168.1.65/29
Servers – 192.168.1.66 – 70/29; Gateway – 192.168.1.66
Servers in other location 10.1.1.1 Port 3030, 10.2.1.1 Port 3030, 10.3.1.1 Port 3030 etc
Can anyone please help me by sharing a sample ACL, which will work for my above requirement?
Thanks in advance
Sangeeth
8 Replies 8
cadet alain
the established keyword only works for TCP not for UDP so you surely have your DNS replies which are blocked.
You'd be better off configuring either CBAC or Zone Based Firewall to achieve a stateful behaviour for all type of traffic.
Post your sanitized config and I'll give you the CBAC and ZBF config to achieve your needs.
Alain
Hi Alain,
Thanks for your replay.
Now the router is running with minimum configuration. I have shared below the running config of the router. Please have a look on that and help me by giving a sample ACL config as you promissed
Please note i have changed the IP addresses.
Router#sh run
Building configuration...
Current configuration : 3986 bytes
! Last configuration change at 11:49:20 UTC Wed Oct 30 2013
version 15.0
boot-start-marker
boot-end-marker
enable password ****
no aaa new-model
no ip source-route
ip cef
no ip domain lookup
license udi pid CISCO2811 sn FHK091390B9
interface FastEthernet0/0
ip address 192.168.1.65 255.255.255.248
ip accounting output-packets
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.62  255.255.255.252
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.1.61
ip access-list extended Allow
permit tcp any any eq www
permit tcp any any eq 443
permit tcp any any eq 8080
permit tcp any any eq domain
permit udp any any eq domain
permit tcp host 10.1.1.1 host 192.168.1.66  eq 3030
permit tcp host  10.1.1.1 host 192.168.1.69 eq 3030
permit tcp host 10.2.1.1 host 192.168.1.66  eq 3030
permit tcp host 10.2.1.1 host 192.168.1.67 eq 3030
permit tcp host 10.2.1.1 host 192.168.1.69  eq 3030
permit tcp host 10.2.1.1 host 192.168.1.70 eq 3030
deny   tcp any any
logging history informational
logging trap debugging
logging 10.125.x.x
logging 10.125.x.x1
logging 10.125.x2.x2
control-plane
privilege interface level 8 shutdown
privilege interface level 8 encapsulation ppp
privilege interface level 8 ip address
privilege interface level 8 description
privilege configure level 0 line
privilege configure level 8 ip route
privilege configure level 8 interface
privilege exec level 6 traceroute
privilege exec level 6 ping
privilege exec level 6 configure terminal
privilege exec level 6 show mac-address-table
privilege exec level 6 show running-config
privilege exec level 6 clear counters
line con 0
line aux 0
line vty 0 4
login local
scheduler allocate 20000 1000
end
Thanks in advance
Sangeeth
There is no NAT or IPSec VPN  involved ?
How do you want to access inside server? with a static PAT or with a VPN ?
Alain
Hi Alain,
All servers having public IP. These devices may be able to access from outside network at presant. That is the reason i changed those IP and put some private IPs.
Thanks and Regards,
Sangeeth BS
So which server is accessible from WAN, on which service and from which IP ?
Alain
Hi Alain,
Right now all my servers are accessible from WAN (Internet).
I just want
  • Communication between my remote servers (10.1.1.1, 10.2.1.1) to my server farm servers (192.168.1.66 to 192.168.1.70) with port no 3030
  • Enable www, https & dns services from internet to server farm servers
  • And all server farm servers should have internet access without any problem.
If i apply the ACL which i showed in the above running config, the first 2 points works fine, but third point fails.
Hop you understood the scenario.
Thanks and Regards,
Sangeeth BS
Is this ACL supposed to be applied on the WAN interface inbound direction?
Based on the configuration you are actually allowing what you need so there should not be any problem.
As a note I would actually add the deny ip any any at the bottom.
deny   tcp any any
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hi Julio,
with these
The inside servers won't receive DNS replies because they don't use port 53 as source so the return traffic must be from port 23 not destined to port 53.
So these 2 lines should be
permit tcp any eq domain any
permit udp any eq domain any
And best would be to specify the DNS server IP addresses to be more specific.
Regards.
Alain
