HSRP catalyst 4506
Hi I have two catalyst sw 4506 and I have set them in so redundate a sw I have already configured with vlans, and routes within my LAN, and that gives me an environment HSRP active - passive.
My 4506  has a 12-port Fo module and  management module is enough with these modules or need any more?
I have to delete the configuration I have in production to implement HSRP.
How should this implementation of HSRP.
Thanks for your help
daniel.dib
Level 7
Level 7
The number of modules needed depends on how many ports you need. Why do you need to delete configuration to implement HSRP? Not sure I understand you.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
I 4506 1 has a configuration and production my 4506 2 has a copy of that configuration.
when you deploy that configuration running HSRP in 4506 1 is not lost?
I have 12 ports to connect to 12 edge sw 2600
Do you mean that they have identical configurations? The IP addresses must be unique at least. HSRP config can be the same but you need to set the priority to make the correct switch active.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
