ACL Nexus 7000 on port blocks everything
uzbayev.marat1
Hi Guys,
I'm trying configure access-list on port-channel in N7K.
Ports connected to ESXi host with ~50 VMs
I want to filter access for only 1 VM (with IP A.B.C.D), with no impact to other VMs.
IP access list TEST
10 permit ip X.X.X.1/32 10.A.B.C.D/32
20 permit ip X.X.X.2/32 10.A.B.C.D/32
30 permit ip X.X.X.3/32 10.A.B.C.D/32
40 permit ip X.X.X.4/32 10.A.B.C.D/32
50 deny ip any any
interface port-channel23
description VM1
switchport
switchport mode trunk
spanning-tree port type edge trunk
ip port access-group TEST in
This is what I applied. And it's block everything, all VMs become unreachable.
Any idea?
What I'm missing (
uzbayev.marat1
ACL in Nexus is applies  to VLAN interface not on port interface
11 Replies 11
marce1000
 - But then the ACL , will do exactly what you want, and will not allow traffic to the other VM's.
M.
Problem that it blocks even traffic to VM1 (
Oh, I also tried this one. Also not work
10 permit ip X.X.X.1/32 A.B.C.D/32
20 permit ip X.X.X.2/32 A.B.C.D/32
30 permit ip X.X.X.3/32 A.B.C.D/32
40 permit ip X.X.X.4/32 A.B.C.D/32
50 deny ip any A.B.C.D/32
Try adding this:
60 permit ip any any
100 permit ip any any
When I use permit any any it allows all traffic, but I need restrict access to VM1. with no impact on VM2
Well, it proves the access list is working, but for some reason the packet which should be blocked doesn't match with the source or destination IP in the first lines.
Are you using NAT?
Nope. NAT is not configured
Yachay
If your plan is to block one VM and allow all traffic to the other ones, then your ACL is wrong. Change 'permit' by 'deny' from 10 to 40, and then change 'deny' by 'permit' in sequence 50.
aim is:
Allow access to VM1 only for X.X.X.1, X.X.X.2, X.X.X.3, X.X.X.4
And block other users
uzbayev.marat1
This is killing me!!!
for test I configured
IP access list TEST2
10 permit ip 10.189.129.45/32 any
Where 10.189.129.45 is my PC.
Logically it should allow traffic from my PC to all VMs. But in practice it blocks everything
uzbayev.marat1
