ACL on interface BVI98
mahesh18
Level 7
Level 7
Hi Everyone,
Router 1811w is configured as Wi fi.
Interface
interface BVI98
 ip address 192.168.98.1 255.255.255.0
 ip virtual-reassembly
 ip tcp adjust-mss 1452
ip dhcp pool WIRELESS
   import all
   network 192.168.98.0 255.255.255.0
   default-router 192.168.98.1
   dns-server 64.59.144.19
   lease 3
User 1 is getting IP 192.168.98.6 from DHCP pool.
User 2 is getting IP 192.168.98.7 from DHCP pool.
I config ACL
ip access-list extended test
 deny   ip host 192.168.98.7 any log
 permit ip any any log
I Apply this to Interface interface BVI98
ip access-group test in
After this ACL if i ping from Router to IP 192.168.98.7 it does not work this is expected behaviour.
But when from PC with IP 192.168.98.6 i ping 192.168.98.7 it works.
Need to know how this ping is working?
Is this ping working because when i ping from PC with IP 192.168.98.6 then that traffic does not hit the int bvi98?
MAhesh
luckymike33
Level 6
Level 6
This is working because the ping traffic not going to your bvi interface, and that is because these two devices are in the same broadcast domain, i.e. they are in the same vlan. However the bvi interface is used to route traffic off that vlan and so the ACl applied to that interface will see traffic despite it belonging to the same vlan.
Do you need more information on bvi interfaces? They should be thought of as very similar to svi interfaces, and used by APs mainly to allow a layer 2 device to participate in routing (i.e. to allow an AP to be managed), Keith Barker has also got a good explanation for them here:
https://learningnetwork.cisco.com/thread/52706
Ask if you need any more info
Mike
luckymike33
Level 6
Level 6
Mike
Thanks Mike for Reply
Mahesh
