ACL on Interface VLAN
ChrisHendry2416
Community Member
I was tasked with setting up a subnet on vlan 250 (172.29.1.0/24) that allowed any users on it access to the internet but not private IP's, so ACL below:
IPV4 ACL OPEN_INTERNET
10 deny ip 172.29.1.0/24 10.0.0.0/8
20 deny ip 172.29.1.0/24 172.16.1.0/12
30 deny ip 172.29.1.0/24 192.168.0.0/16
40 permit ip any any
This has been applied to a single interface vlan 250
interface Vlan250
description INTERNET ONLY WIFI
no shutdown
ip access-group OPEN_INTERNET out
ip address 172.29.1.1/24
However, in testing I am still able to get to private IP's on this subnet. This is on a Nexus 5K connected to a stack of 2960's.
Do I need to apply this to a physical interface for it to work properly?
Joseph W. Doherty
Try using that ACL"in".
5 Replies 5
Joseph W. Doherty
Thank you, that seems to have done the trick for stopping access to internal resources, however, now I am unable to get a consistent connection.  My Phone says no internet on this Wi-Fi but can still ping 8.8.8.8.  Do I need to specify and "OUT" ACL on this interface to allow traffic from outside to this network as well?
I've grown use to our Firewall which has stateful connections that I forget if it is required to specify in and out on these?
"I've grown use to our Firewall which has stateful connections that I forget if it is required to specify in and out on these?"
On a SVI. "in" is from VLAN's hosts.  "Out" is to the VLAN's hosts..
"Do I need to specify and "OUT" ACL on this interface to allow traffic from outside to this network as well?"
You could.  Using just a single direction ACL blocks two way communication, but not one way communication.  (However, in this case, since you are allowing communication to the Internet, and likely that's also via NAT/PAT and a FW, "unrequested" data, from the Internet, would likely have much difficulty reaching that VLAN.)
Check these
1- make direction IN not OUT
2- check tcam have room for this ACL
ChrisHendry2416
Community Member
I made a stupid mistake there a the end, our DNS was set internally so of course we couldnt find anything.
