ACL on Switch 3550 (with routing enabled)
MUKADI Pierre
Hi there
Can you help me?
I'm configuring acl on my cisco but it doesn't work.
My network looks like this :
Internet  <--->(eth0) MikrotikRouter (eth1) <--->(fa0/1) Cisco switch (3550) (int vlanX) <---> Internal VLANs
1. On my MIKROTIK :
- I have a public IP and NAT configure
- I have RIP v2 configure on the internal interace (eth1) : 172.16.1.1
- I have some rule that block microsoft downloading site, social network, steaming, etc.
2. On my Cisco switch (3550):
- I have Routing enabled, RIP v2 enabled, networks (To and From Mikrotik network: 172.16.1.1, VLANs networks:192,168.0.0/24) configured, ...
My problem is :
Without ACL, the internet is working.
But when I configure the ACL, internet does not pass.
NB : Ping and DNS work : ping google.fr is ok
         But Internet (on browser) does not work. Telnet on port 80, etc. does not work.
MY ACL is :
no access-list 111
no access-list 112
access-list 111 permit tcp host 192.168.1.25  any eq 23
access-list 111 permit tcp host 192.168.1.26  any eq 23
access-list 111 permit tcp host 192.168.2.25  any eq 23
access-list 111 permit tcp host 192.168.2.26  any eq 23
access-list 111 permit udp host 192.168.1.25  any eq 23
access-list 111 permit udp host 192.168.1.26  any eq 23
access-list 111 permit udp host 192.168.2.25  any eq 23
access-list 111 permit udp host 192.168.2.26  any eq 23
access-list 111 permit tcp any any eq www
access-list 111 permit tcp any any eq 8080
access-list 111 permit tcp any any eq smtp
access-list 111 permit tcp any any eq pop3
access-list 111 permit tcp any any eq 443
access-list 111 permit tcp any host 8.8.8.8 eq 53
access-list 111 permit ip host 8.8.8.8 any
access-list 111 permit tcp any any eq 53
access-list 111 permit tcp any any eq 22
access-list 111 permit tcp any any eq 20
access-list 111 permit tcp any any eq 21
access-list 111 permit tcp any any eq 175
access-list 111 permit tcp any any eq 194
access-list 111 permit tcp any any eq 465
access-list 111 permit tcp any any eq 902
access-list 111 permit tcp any any eq 993
access-list 111 permit tcp any any eq 995
access-list 111 permit tcp any any eq 1194
access-list 111 permit tcp any any eq 5060
access-list 111 permit udp any any eq 20
access-list 111 permit udp any any eq 21
access-list 111 permit udp any any eq 53
access-list 111 permit udp any any eq 67
access-list 111 permit udp any any eq 68
access-list 111 permit udp any any eq bootps
access-list 111 permit udp any any eq 5060
access-list 111 permit udp any any eq 3128
access-list 111 permit udp any any eq rip
access-list 111 permit icmp any any echo-reply
access-list 111 permit icmp any any unreachable
access-list 111 permit icmp any any time-exceeded
access-list 111 deny   icmp any any
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq www
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 8080
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 443
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 53
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq smtp
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq pop3
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 22
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 20
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 21
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 175
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 194
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 465
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 902
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 993
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 995
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 1194
access-list 111 permit tcp any 172.16.1.0 0.0.0.255 eq 5060
access-list 111 permit udp any 172.16.1.0 0.0.0.255 eq 20
access-list 111 permit udp any 172.16.1.0 0.0.0.255 eq 21
access-list 111 permit udp any 172.16.1.0 0.0.0.255 eq 53
access-list 111 permit udp any 172.16.1.0 0.0.0.255 eq 67
access-list 111 permit udp any 172.16.1.0 0.0.0.255 eq 68
access-list 111 permit udp any 172.16.1.0 0.0.0.255 eq bootps
access-list 111 permit udp any 172.16.1.0 0.0.0.255 eq 5060
access-list 111 permit udp any 172.16.1.0 0.0.0.255 eq 3128
access-list 111 permit udp any 172.16.1.0 0.0.0.255 eq rip
access-list 111 permit tcp  172.16.1.0 0.0.0.255 any established
inter range vlan 1 - 20
no ip access-group 111 out
exit
Iulian Vaideanu
Level 4
Level 4
If I understood your topology correctly I believe what you want is "ip access-group 111 in", not "out"...
