ACL problem
StanDamen
Level 3
Level 3
Im trying to define ACL's for use in policy based routing
problem is i need to specify 2 ACLs,
one that puts traffic from 10.5.0.1 to 10.5.0.6 destination 172.17.0.0/24 through hop 10.4.0.1
and another that puts 10.5.0.7 to 10.5.0.12 destination 172.17.0.0/24 through hop 10.4.0.2
How do i do this with ACLs? I did:
access-list 101 permit ip 10.5.0.1 0.0.0.7 172.17.0.0 0.0.0.255
access-list 102 permit ip 10.5.0.7 0.0.0.7 172.17.0.0 0.0.0.255
both both result in ACL:
access-list 102 permit ip 10.5.0.0 0.0.0.7 172.17.0.0 0.0.0.255
any idea how to do this?
following are the route-maps:
route-map customers permit1
match ip address 101
set ip next-hop 10.4.0.1
route-map customers permit2
match ip address 102
set ip next-hop 10.4.0.2
Thanks in advance!
5 Replies 5
Ganesh Hariharan
Thanks in advance!
You want two separate network to flow with separet next hops if yes try with these ACL and share the results
access-list 101 permit ip 10.5.0.0 0.0.0.7 172.17.0.0 0.0.0.255
access-list 101 permit ip 10.5.0.7 255.255.255.255 172.17.0.0 0.0.0.255
access-list 102 permit ip 10.5.0.8 0.0.0.7 172.17.0.0 0.0.0.255
Check out the below link on PBR also for more information
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481d.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Hi Ganesh!
It gave me this result:
access-list 101 permit ip any 172.17.0.0 0.0.0.255
Which is not precisely what i wanted, but at least 10.5.0.8 0.0.0.7 is now shown.
It should start at 10.5.0.7 though.
The second line pretty much negates the other lines, so that needs changing. However if i remove it (no access-list 101 permit ip any 172.17.0.0 0.0.0.255
) it removes the entire access list.
Is there any other way?
Hi Ganesh!
If you see my previous post in first line host 1 to 6 will come and  second line was for single host that is 10.5.0.7 and acl 102 is for network 10.0.5.8/29
Ganesh.H
Yes, but this:
gives this in show run:
Which means access list 102 will never apply to anything will it? since "any" covers everything.
Thanks!
Yes, but this:
Thanks!
It's really starnge can you try with below option :-
1) try configure named acl for extended and type the first network and second line with permit ip host 10.5.0.7 172.17.0.0 0.0.0.255
or
2) Try configure 3 ACL one for host 1 to 6, one for host 7 and lastly for 8 to 14
Ganesh.H
