ACL question
mahesh18
Level 6
Level 6
Hi all,
I have applied extended ACL on my Routers Lan int fa1/0 to block pings from my Lan to any outside IP.
Here is config
interface FastEthernet1/0
ip dhcp relay information trusted
ip access-group 100 in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
Here is ACL config
access-list 100 deny   icmp any any echo log-input
access-list 100 permit ip any any
Here is test results
2650xm#                                            ping 4.2.2.2*******************outside IP
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 44/45/48 ms
2650xm#ping 192.168.1.1*****************************IP of Lan interface of router
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
U.U.U
Success rate is 0 percent (0/5)
2650xm#ping 96.51.x.x*************************************************Router IP of wan interface
Sending 5, 100-byte ICMP Echos to 96.51.x.x , timeout is 2 seconds:
U.U.U
2650xm#
Can someone please explain me why we are able to ping any outside IP even we have applied ACL on routers lan interface fa1/0 and we are not able to ping the router wan interface fa0/0 IP 96.x.x.x and 192.168.1.1
thanks
mahesh
Jon Marshall
Mahesh
You can ping any outside address because you are pinging from the router so the router will use it's WAN interface as the source IP and you haven't applied the acl there. If you want to test it properly ping an outside IP from a client on your LAN.
Jon
Jon Marshall
Mahesh
Jon
Hi Jon,
Thanks for wonderfull explanation
thanks
mahesh
