ACL
tarun_cisco
Community Member
By any chance can I block tcp web session using standard access list at all or only extended is option?
7 Replies 7
cadet alain
You want to block all http or some urls?
Regards.
Alain.
tarun_cisco
Community Member
Want to block whole http please.
tarun_cisco
Community Member
tarun_cisco
Community Member
tarun_cisco
Community Member
you can add this to your acl and this will block tcp traffic on port 80, for https use port 443. Remember there is an explicit deny at the end of the access list.
e.g. access-list 101 deny tcp any any eq 80
Alex
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Yes, its possible with a standard ACL although its not very granular.  I.e., you're likely block other traffic too, e.g. all traffic from an address block.
An extended ACL will allow a much more specific ACE such as bocking TCP port 80.
However, even an extended ACL might not be specific enough.  You might need something like NBAR and/or FPM to truly block a specific web session, since these technologies can identify HTTP traffic using other than port 80 and/or URL contents.
