ACLs
RaymondBui97693
Frequent Visitor
Frequent Visitor
I am trying to lock down some VLANs on a Cisco Cataylst 3850 with IOS XE 16.12.9 Gibraltar
I need vlan 101 to talk to 102 and 103 and get out to the internet
I need 103 to only talk to 101 and 102 with no internet
I tried to apply this ACL to 103 but can still ping everything
ip access-list extended 103
permit ip any 192.168.101.0 0.0.0.255
permit ip any 192.168.102.0 0.0.0.255
deny ip any any
interface vlan 103
ip access group 103 in
8 Replies 8
deny ip any any
interface vlan 103
ip access group 103 OUT
M02@rt37
hello @RaymondBui97693,
ip access-list extended 101
permit ip any any
permit ip 192.168.101.0 0.0.0.255 any
permit ip 192.168.102.0 0.0.0.255 any
deny ip any any
interface Vlan101
ip access-group 101 in
interface Vlan103
ip access-group 103 in
With this configuration, VLAN 101 has unrestricted access to communicate with VLANs 102 and 103, as well as access to the internet. On the other hand, VLAN 103 is limited to communication with VLANs 101 and 102 but does not have internet access.
Best regards
Jon Marshall
There is nothing wrong with your configuration ie. it should work because the acl is correct and is applied in the correct direction.
Is there any other path the clients could take to get to the internet,  are you running HSRP etc. ?
Jon
Jon:
All our sites are connected via SD-WAN.
johnlloyd_13
Level 11
Level 11
hi,
you can try using private VLAN config.
RaymondBui97693
Frequent Visitor
Frequent Visitor
Is there a way to block ping to all the vlans. We want to confirm that there is no communication via ping.
meaning between all VLAN ?
if yes
vlan x
ip add x.x.x.x
ip access-group icmp IN
ip access-list icmp
deny icmp x.x.x.x any
permit ip any any
that it
If you want to block ping  from 192.168.103.x to 192.168.101.x and 192.168.102.x add these lines at the top of your 103 acl -
deny icmp any 192.168.101.x echo
deny icmp any 192.168.102.x echo
as I said previously your configuration is correct so something else is happening here.
Jon
