Active Monitor sessions on 6880
reachomer_khan
We can have 2 active local Span sessions in 6500, however I need to confirm how many can I have on 6880 at same time.
It is the same Family as 6500 but want to confirm, as I am looking for 3 Active Local sessions on 6880.
Mark Malone
Hey its more the sup than the chassis what have you got as the supervisor ?
if its 2T its the same as 6500 just 2
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-1SY/config_guide/sup2T/15_1_sy_swcg_2T/span_rspan_erspan.html
Thanks for the update Mark. I have  C6880-X-LE. I will check the link now.
C6880-X-LE uses the concept of SUp-2T hence the following session limits applied to it.
Local SPAN, RSPAN, and ERSPAN Session Limits
Total Sessions
Local and Source Sessions
Destination Sessions
Local SPAN,
RSPAN Source,
ERSPAN Source
Ingress or Egress or Both
Local SPAN Egress-Only
RSPAN
ERSPAN
80
64
23
Local SPAN, RSPAN, and ERSPAN Interface Limits
chsarkar
Here goes the limitations :
Total Sessions
Local SPAN,
RSPAN Source,
ERSPAN Source
RSPAN
ERSPAN
80
64
23
Cheers !
** Do not forget to rate any posts if found helpful **
