Add d-link DES-1210-28p switch to cisco network??
Ivan Marinovic
In our organization we have only cisco switches.. 6509 core, 3750 as distribution, and 2960 as access switch... now we receive d-link 1210-28p switch.
is it possible to add d-link DES-1210-28p switch on cisco 2960 switch and to have voice vlan and other vlan??
On cisco switch i configured port:
interface FastEthernet0/22
switchport trunk allowed vlan 8,24
switchport mode trunk
switchport nonegotiate
switchport voice vlan 8
switchport port-security maximum 24
switchport port-security aging time 10
switchport port-security violation restrict
switchport port-security aging type inactivity
ip arp inspection limit rate 500
srr-queue bandwidth share 10 10 60 20
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input AutoQoS-Police-CiscoPhone
and on dlink i add two vlan 8 (for voice) and 24 for network...
But it is not working....
when cisco port is set to access i can go on internet but voice is not working!!
any suggestion??
regards,
IVan
Giuseppe Larosa
Hello Ivan,
from your qos configuration it looks like you have Cisco IP phones
with default settings cisco IP Phones uses Cisco CDP to discover the voice Vlan, you should verify if:
your switches both the C2960 and the D-link supports LLDP-MED that is the standards based equivalent of CDP
if the CUCM version or call manager express version allows to configure the phones to use LLDP-MED and so on
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swlldp.html
and then also for CUCM ot CUCME
the following link provides information on CDP vs. LLDP-MED
http://www.cisco.com/en/US/technologies/tk652/tk701/technologies_white_paper0900aecd804cd46d.html
using google search you can find:
http://www.manualowl.com/m/D-Link/DGS-1210-10P/Manual/157272?page=64
Probably, you may be able to set the voice vlan manually on the phones as an alternate way to all above
Hope to help
Giuseppe
