Double NAT over GRE
james.reeves
I am trying to setup a connection in my router that will staticly translate the sourec and destination of a packet and then send it over the GRE tunnel.
Original packet S-10.10.10.10 D-10.20.20.20
XLATE router
Desired packet
Global Packet S-172.16.10.10 D-172.16.20.20
Gig0/0
ip nat inside
ip accounting output-packets
Loopback 10
ip address 10.20.20.1/24
Tunnel4
ip nat outside
ip nat inside source static 10.10.10.10   10.20.20.20
ip nat outside source static 172.16.20.20 172.16.10.10
ip route 172.16.20.0/24 tunnel4
If I do a traceroute and source it from the loopback interface it works fine and I see the traffic hitting the upstream router.  When actual traffic traverses I see it hit the xlate table but I never see it on the upstream router.  I do see my ping and traceroute in ip accounting.
Any ideas?
Yes. For an inside to outside translation routing decision occurs first.  Accordingly NAT occurs then. Here is the cisco page for NAT order of operation -
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
skarthic
So you are saying that the NAT translations are seen in the NAT table.
Could you paste the output of "debug ip nat detailed" and the " debug ip packet detail"
Also does the "sh ip nat translations" show the complete translation being made?
I believe I have found the issue.  There is a static route in the configuration for the local outside address pointing out another interface.  I am assuming the router would route the traffic first and then translate still on the outbound interface.
Would you agree?
Thank you.
