Added switch to network and err-disabled part of the network, why?
Andy White
Level 3
Level 3
Still not sure how I did this even after looking at the log files which are below.  Anyway we have a LAN which has 2 Nortel 8600 Core switch which are trunked together (IST - Nortel Etherchannel).  Off each Nortel are etherchannels to 2 Cisco 3750 stacks where our VMware farm and Storage SANs are connected.
I plugged the Cisco 3750 into the Nortel switch shown above (port 1/27) and at that point I was fine, but when I on to the Nortel GUI manager and selected port 1/27 and these 3 options, band ports 12,24 on the 2 Cisco stacks went into error disable:
  • Perform Tagging
  • Discard Untagged Frames
  • Loop Detection
I then clicked apply and that did the trick and all went down.  I have a feeling it was the Loop Detection that cause the issue but why?
Here are the logs and the Cisco switch config I added.
Did the 2 Cisco stacks see the mac from 2 loctions?  What is strange I've don this one before on the other Nortel Core and it was fine.  I hate those Nortels.
# Generated by Syslog Viewer
# Version 2013.1.0
# 06/09/2013 18:06:42
# Syslog Messages
# 06 September 2013 06:06 PM
Gi3/0/33"          SW_MATM-4-MACFLAP_NOTIF          320517892
"06/09/2013 15:43:44"          192.168.28.251          192.168.28.251          Error          "26108:   Interface GigabitEthernet1/0/24, changed state to down"          LINK-3-UPDOWN          320517882
"06/09/2013 15:43:44"          192.168.28.251          192.168.28.251          Error          "26107:   Interface Port-channel1, changed state to down"          LINK-3-UPDOWN          320517891
"06/09/2013 15:43:43"          192.168.28.251          192.168.28.251          Notice          "26103:   Line protocol on Interface GigabitEthernet1/0/12, changed state to down"          LINEPROTO-5-UPDOWN          320517883
"06/09/2013 15:43:43"          192.168.28.251          192.168.28.251          Notice          "26104:   Line protocol on Interface GigabitEthernet1/0/24, changed state to down"          LINEPROTO-5-UPDOWN          320517885
"06/09/2013 15:43:43"          192.168.28.251          192.168.28.251          Notice          "26105:   Line protocol on Interface Port-channel1, changed state to down"          LINEPROTO-5-UPDOWN          320517887
"06/09/2013 15:43:43"          192.168.28.251          192.168.28.251          Error          "26106:   Interface GigabitEthernet1/0/12, changed state to down"          LINK-3-UPDOWN          320517889
"06/09/2013 15:43:42"          192.168.28.251          192.168.28.251          Warning          "26101:   channel-misconfig (STP) error detected on Po1, putting Gi1/0/24 in err-disable state"          PM-4-ERR_DISABLE          320517888
"06/09/2013 15:43:42"          192.168.28.251          192.168.28.251          Warning          "26100:   channel-misconfig (STP) error detected on Po1, putting Gi1/0/12 in err-disable state"          PM-4-ERR_DISABLE          320517886
"06/09/2013 15:43:42"          192.168.28.251          192.168.28.251          Warning          "26099:   channel-misconfig (STP) error detected on Gi1/0/24, putting Gi1/0/24 in err-disable state"          PM-4-ERR_DISABLE          320517884
"06/09/2013 15:43:42"          192.168.28.251          192.168.28.251          Warning          "26098:   channel-misconfig (STP) error detected on Gi1/0/12, putting Gi1/0/12 in err-disable state"          PM-4-ERR_DISABLE          320517881
"06/09/2013 15:43:42"          192.168.28.251          192.168.28.251          Warning          "26102:   channel-misconfig (STP) error detected on Po1, putting Po1 in err-disable state"          PM-4-ERR_DISABLE          320517890
"06/09/2013 15:43:31"          192.168.28.250          192.168.28.250          Warning          "29404: 032029:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1)."          CDP-4-NATIVE_VLAN_MISMATCH          320517880
"06/09/2013 15:43:31"          192.168.28.250          192.168.28.250          Warning          "29405: 000045:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1). (ISCSI-3750-A-1)"          CDP-4-NATIVE_VLAN_MISMATCH          320517879
"06/09/2013 15:43:31"          192.168.28.251          192.168.28.251          Warning          "26097:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1)."          CDP-4-NATIVE_VLAN_MISMATCH          320517878
"06/09/2013 15:42:32"          192.168.28.250          192.168.28.250          Warning          "29403: 000044:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1). (ISCSI-3750-A-1)"          CDP-4-NATIVE_VLAN_MISMATCH          320517875
"06/09/2013 15:42:31"          192.168.28.251          192.168.28.251          Warning          "26096:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1)."          CDP-4-NATIVE_VLAN_MISMATCH          320517873
"06/09/2013 15:42:31"          192.168.28.250          192.168.28.250          Warning          "29402: 032028:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1)."          CDP-4-NATIVE_VLAN_MISMATCH          320517874
"06/09/2013 15:42:27"          192.168.28.250          192.168.28.250          Notice          "29401: 032027:   Line protocol on Interface Vlan23, changed state to down"          LINEPROTO-5-UPDOWN          320517872
"06/09/2013 15:42:26"          192.168.28.251          192.168.28.251          Notice          "26095:   Line protocol on Interface Vlan23, changed state to down"          LINEPROTO-5-UPDOWN          320517871
"06/09/2013 15:42:26"          192.168.28.251          192.168.28.251          Notice          "26094:   Line protocol on Interface Vlan1, changed state to down"          LINEPROTO-5-UPDOWN          320517870
"06/09/2013 15:42:26"          192.168.28.251          192.168.28.251          Critical          "26093:   Blocking Port-channel1 on VLAN0023. Inconsistent local vlan."          SPANTREE-2-BLOCK_PVID_LOCAL          320517869
"06/09/2013 15:42:26"          192.168.28.251          192.168.28.251          Critical          "26092:   Blocking Port-channel1 on VLAN0001. Inconsistent peer vlan."          SPANTREE-2-BLOCK_PVID_PEER          320517868
"06/09/2013 15:42:26"          192.168.28.251          192.168.28.251          Critical          "26091:   Received BPDU with inconsistent peer vlan id 1 on Port-channel1 VLAN23."          SPANTREE-2-RECV_PVID_ERR          320517867
"06/09/2013 15:42:26"          192.168.28.250          192.168.28.250          Critical          "29400: 032026:   Blocking Port-channel1 on VLAN0023. Inconsistent local vlan."          SPANTREE-2-BLOCK_PVID_LOCAL          320517866
"06/09/2013 15:42:26"          192.168.28.250          192.168.28.250          Critical          "29399: 032025:   Blocking Port-channel1 on VLAN0001. Inconsistent peer vlan."          SPANTREE-2-BLOCK_PVID_PEER          320517865
"06/09/2013 15:42:26"          192.168.28.250          192.168.28.250          Critical          "29398: 032024:   Received BPDU with inconsistent peer vlan id 1 on Port-channel1 VLAN23."          SPANTREE-2-RECV_PVID_ERR          320517864
"06/09/2013 15:41:32"          192.168.28.250          192.168.28.250          Warning          "29397: 000043:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1). (ISCSI-3750-A-1)"          CDP-4-NATIVE_VLAN_MISMATCH          320517861
"06/09/2013 15:41:31"          192.168.28.251          192.168.28.251          Warning          "26090:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1)."          CDP-4-NATIVE_VLAN_MISMATCH          320517860
"06/09/2013 15:41:31"          192.168.28.250          192.168.28.250          Warning          "29396: 032023:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1)."          CDP-4-NATIVE_VLAN_MISMATCH          320517859
"06/09/2013 15:40:31"          192.168.28.250          192.168.28.250          Warning          "29394: 032022:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1)."          CDP-4-NATIVE_VLAN_MISMATCH          320517856
"06/09/2013 15:40:31"          192.168.28.250          192.168.28.250          Warning          "29395: 000042:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1). (ISCSI-3750-A-1)"          CDP-4-NATIVE_VLAN_MISMATCH          320517855
"06/09/2013 15:40:31"          192.168.28.251          192.168.28.251          Warning          "26089:   Native VLAN mismatch discovered on GigabitEthernet1/0/24 (23), with Helpdesk_Switch.CBSO GigabitEthernet1/0/12 (1)."          CDP-4-NATIVE_VLAN_MISMATCH          320517854
From one of the heldesk cisco switch I added that caused the issue.
*Mar  1 00:29:09.961: %PARSER-5-CFGLOG_LOGGEDCMD: User:console  logged command:ip dhcp snooping vlan 80
*Mar  1 00:29:22.997: %PARSER-5-CFGLOG_LOGGEDCMD: User:console  logged command:ip dhcp snooping
*Mar  1 00:30:10.050: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 00:40:11.588: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 00:42:02.462: %PARSER-5-CFGLOG_LOGGEDCMD: User:console  logged command:ip default-gateway 192.168.23.253
*Mar  1 00:42:03.435: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 00:54:38.807: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/12, changed state to up
*Mar  1 00:54:40.828: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12, changed state to up
*Mar  1 00:57:44.483: %SPANTREE-2-RECV_PVID_ERR: Received BPDU with inconsistent peer vlan id 23 on GigabitEthernet1/0/12 VLAN1.
*Mar  1 00:57:44.483: %SPANTREE-2-BLOCK_PVID_LOCAL: Blocking GigabitEthernet1/0/12 on VLAN0001. Inconsistent local vlan.
*Mar  1 00:59:11.969: %SPANTREE-2-UNBLOCK_CONSIST_PORT: Unblocking GigabitEthernet1/0/12 on VLAN0001. Port consistency restored.
*Mar  1 00:59:27.907: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12, changed state to down
*Mar  1 00:59:28.922: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/12, changed state to down
*Mar  1 03:28:31.432: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: Andyw] [Source: 0.0.0.0] [localport: 0] at 03:28:31 UTC Mon Mar 1 1993
Helpdesk_Switch#sh run
Building configuration...
Current configuration : 3563 bytes
version 12.2
no service pad
hostname Helpdesk_Switch
boot-start-marker
boot-end-marker
logging console informational
enable secret 5 $1$gyXtMMoalpx1SAcS7T.
username ***
no aaa new-model
switch 1 provision ws-c3750g-12s
system mtu routing 1500
ip domain-name ***
ip dhcp snooping
login on-failure log
login on-success log
archive
log config
  logging enable
  logging size 200
  notify syslog contenttype plaintext
  hidekeys
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
ip ssh version 2
interface GigabitEthernet1/0/1
switchport access vlan 80
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
(removed)
interface GigabitEthernet1/0/12
description Trunk to Nortel
switchport mode trunk
ip arp inspection trust
ip dhcp snooping trust
interface Vlan1
no ip address
shutdown
interface Vlan23
ip address 192.168.23.9 255.255.255.0
ip classless
no ip http server
no ip http secure-server
logging trap notifications
logging source-interface Vlan23
logging 192.168.*.*
access-list 20 permit 192.168.*.* log
access-list 24 permit 192.168.*.*
snmp-server community *** RO 24
snmp-server host 192.168.*.* ***
line con 0
exec-timeout 15 0
logging synchronous
login local
line vty 0 4
access-class 20 in
exec-timeout 15 0
logging synchronous
login local
transport input ssh
line vty 5 15
access-class 20 in
exec-timeout 15 0
logging synchronous
login local
transport input ssh
ntp logging
ntp clock-period 36029310
ntp source Vlan23
ntp server 192.168.*.*
end
Helpdesk_Switch#
19 Replies 19
Andy and everyone,
I apologize for intruding into this thread... What caught my attention was actually the reason why the ports appear to get err-disabled:
This would mean that the ports in the Po1 EtherChannel bundle were receiving conflicting BPDUs - BPDUs that were sourced from different ports, perhaps even indicated different costs or port priorities. At the very least, the BPDUs were either sourced from different MAC addresses or differed in their Sending Port IDs. This would be a strong indication that the ports on the opposite switch were not operating as an EtherChannel bundle - otherwise the BPDUs would be sourced from a single MAC address and would be identical.
Andy, are you using LACP to negotiate the EtherChannel creation, or are you using the on mode?
Best regards,
Peter
I agree with Peter.
Hence thats the reason I always recommend to disable the interface atleast at one end,  followed by Creating the port-channel first @ bot the side then assign the same to the interface and enable the interface. This will avoid all the unreliable circumstances and bring up the port-channel without any issues.
REgards
Inayath
Inayath,
Thank you! Your suggestion is bullet-proof - it would work all the time. I also feel, however, that it could introduce outages to the network because of the obvious fact of deactivating ports. My personal suggestion is to always use negotiated EtherChannels, either via LACP or via PAgP. Until these protocols negotiate the creation of an EtherChannel, both switches will treat the physical ports as being individual, and neither the EtherChannel STP Misconfig Guard will trip (as in this case), nor switching loops will ensue. It shall not be necessary to shut down ports when using LACP/PAgP.
Would that be your opinion as well - to always go with LACP or PAgP instead of the static "on" mode, in which case it is not necessary to shutdown ports?
Best regards,
Peter
100% Agree with you. Always use one of the negotiation protocol when running etherchanel either with LACP/PAGPrather than "on" mode. +5 for you :-)
Yes but you know I have seen many people missing this piece of information and getting into loops. Hence it has become a practise for me to suggest this to many of them which have saved there time ...again as you said this needs the downtime as they need to shut the interface for some time.
Inayath.
Hi guys, really appreciate all you input, here is the port info for both etherchannels on both stacks:
Stack A
sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Po1         on               802.1q         trunking      23
Port        Vlans allowed on trunk
Po1         1-4094
Port        Vlans allowed and active in management domain
Po1         1,23,1017-1019
Port        Vlans in spanning tree forwarding state and not pruned
Po1         1,23,1017-1019
sh etherchannel sum
Group  Port-channel  Protocol    Ports
1      Po1(SU)          -        Gi1/0/12(P) Gi1/0/24(P)
description Dot1q Trunk to Nortel Core 1 port 1/45
switchport trunk native vlan 23
flowcontrol receive on
channel-group 1 mode on
end
interface GigabitEthernet1/0/24
description Dot1q Trunk to Nortel Core 2 port 1/45
end
Stack B
sh int trunk
Po1         1-4094
Po1         1,23,1018-1019
Po1         1,23,1018-1019
sh ether sum
description Dot1q Trunk to Nortel Core 1 port 2/45
end
description Dot1q Trunk to Nortel Core 2 port 2/45
end
