adding a TenGiga module in cisco WS-C6509-E
hi.sadiki
I have to add a TenGig card in my cisco WS-C6509-E.
We usualy add WS-X6708-10GE. But currently we only have WS-X6708-10G-3C left.
I already looked in cisco website for the compatibility but i am still unsure.
1- Is the WS-X6708-10G-3C works fine on the switch WS-C6509-E ?
2 - what is the difference between WS-X6708-10GE and WS-X6708-10G-3C ?
Thanks for your help.
Hicham SADIKI
Reza Sharifi
It depends on your sup. If your sup is 3CXL, than you need WS-X6708-10G-3CXL card.  If your sup is not XL, than you can put WS-X6708-10G-3C but it will function as a non-XL card.
see link:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/product_data_sheet09186a00801dce34.html
my sup is a :
 5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G
what do you think
The part number should have 3C or 3CXL at the end of it.
have a look at table-1 for the correct part numbers.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/product_data_sheet09186a0080159856.pdf
