Adding or removing WIC/VWIC
rmcole
Greetings,
This should be a quick question.
Can I remove a VWIC and replace it with a WIC without having to power down the router?
dgahm
Level 8
Level 8
No, you must power it down. Even larger routers like 3800 or 3660s that support hotswapping of NMs require a power down for VWICs and WICs.
Please rate helpful posts.
dgahm
Level 8
Level 8
BTW, I meant to say thanks.
Rick,
The rating and the check mark says it all. You are very welcome.
Regards, Dave
