Adding SSH to Nexus 9000 series switches
John N
I am setting up 4 new Nexus switches.  I just finished adding VLANs.  I understand to add SSH you do not add to a VTY line as other switches but instead do a feature ssh.  The steps I followed are below and I am still unable.
conf t
ssh key rsa 2048 force
feature ssh
show ssh key
copy-running config startup-config
I got the error below when i run a show ssh key
count not retrieve dsa key information
could not retrieve ecdsa key information
12 Replies 12
I think this is normal' ssh support three key algo
1- rsa
2- dsa
3- ecdsa
You add key only for rsa so other two algo missing key.
This make you access nexus via ssh using only rsa.
No problem
MHM
I am still unable to ssh in for some reason....
 - @John N              What happens when you try ?
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
It just times out.
Debug ssh all <<- share this when you try to ssh to nexus
MHM
Hmm weird there isn't a debug ssh however I was able to find debug ip packet protocol 22.  I ran it and nothing happened but it did accept the command however no output.
Nothing appear'
You can ping from PC to mgmt vlan IP?
MHM
No i am unable to even do that... so its confusing - For this brand of Nexus it appears there is out of band Mgmt 0 IP which is different then the switch level IP which is created on the VLAN's if i am not mistaken.
Correct' mgmt have it vrf rib and separate from data rib that why ping failed and ssh.
Try
1- add vlan x to any port
2- config svi for vlan x
3- use IP in PC in same subnet of vlanx
4- connect PC to port assign to vlan x
Then try ping' if you sucess then try ssh
(Share result of debug if it failed)
MHM
  - @John N            Check logs on the nexus when trying to connect ,
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Stefan Mihajlov
Level 3
Level 3
@John N
Hi John,
On Nexus switches that output is completely normal. The system will only display information for the key types you’ve actually generated, so since you created an RSA key, the messages about DSA and ECDSA just mean those keys don’t exist — they’re not errors that prevent SSH from working. The important part is that feature ssh is enabled, the RSA key is present, and you have at least one local user with a password and role defined. As long as the management interface has IP reachability, you should be able to connect via SSH from an external host without issues.
Best regards,
Stefan Mihajlov
Mark this post as Helpful if it helped you, and Accept as Solution if it resolved your question.
Still no luck.. I am unsure but I also found the switches can't ping each other....might be unrelated but interesting.
