Adding VLAN to Po-Group and OSPF routing what is the correct way?
ITAdmin777
Hi Community,
I recently had an issue that brought down the links between a couple of switches...luckily this was done after hours and I did not save the config so was able to revert back.
The basic scope of my project is:
We are running out of IP's on the 192.168.1.0/24 sunbnet so wanted to create a seperate VLAN/Subnet  for physical workstations.
He is what I orginally did;
1) On our core switch; (Switch1)
     Create the VLAN,
     VLAN interface,
     DHCP pool,
     excluded address'
2) On second  switch (Switch 2)
     Add VLAN name, no interface
3) I then updated the PO-group on Switch1 with new VLAN  (this brought down the link before I was able to finish my config)
    Therefore I was not able to complete the following:
          add vlan to spanning-tree or updated OSPF routing
______________________________________________
Here is what I assume to be the correct order?
1) On Core Switch (Switch 1)
     Create VLAN
     VLAN interface
     DHCP pool
     excluded address'
     add vlan (passive interface) and sunbet to OSPF routing
2) On Switch 2
     Add vlan name/interfaces with no ip
3) Update PO groups after the above has been configured
     Add new VLAN to Po-Group on Switch 2
     Add new VLAN to Po-Group on Switch 1
4) Last steps
     Updated specific access ports with new VLAN and test
     upon completion of testing, update all other access ports connected ot workstations with new VLAN
Questions:
Did my links go down because I added new VLAN to Po-group BEFORE  updating spanning-tree and OSPF routing?
Can anyone verify the order as outlined in the section "Here is what I assume to be the correct order"
5 Replies 5
Jon Marshall
OSPF no, STP probably not assuming you are running PVST+ or rapid PVST+ on your switches.
This is the way i would do it -
1) create new vlan and SVI on core switch
2) set STP priority for that vlan on core switch
3) if you are running VTP transparent create the vlan on the second switch
3) open windows to both switches and have a cut and paste config to add the vlan to the port group
then when all that has been done add the OSPF configuration.
Jon
Hello jon....thanks for te advise.
Can you review my config:
To Summarize
Step 1 -     On Switch1 - Create VLAN, interface, DHCP scope, excluded address'
                 On Switch 2 - Create the VLAN and I nterface with no ip
Step 2 -     Set STP priority
Step 3 -     Update PO-groups on Switch2 and Switch 1
Step 4 -      Add new VLANs to OSPF as passive interface
__________________________________________________________________
So therefore , something like this
FYI: We are running in VTP transparent MODE
Step 1 - Create the VLAN, interface, DHCP scope, excluded address list
On SWITCH1 (core)
Task: Add new VLAN's (40 & 41)
RESULT:
vlan 40
name vDesktops(192.168.40.0/24)
vlan 41
name WRKSTNs(192.168.41.0/24)
________
TASK:  Assign IP to VLAN (40 & 41) interfaces
RESULT:
interface Vlan40
ip address 192.168.40.254 255.255.255.0
interface Vlan41
ip address 192.168.41.254 255.255.255.0
_______
TASK: Create the DHCP scope for the new VLANs
RESULT:
ip dhcp pool VLAN40
   network 192.168.40.0 255.255.255.0
   default-router 192.168.40.254
   domain-name myDomain.com
   dns-server 192.168.1.44 192.168.1.45
ip dhcp pool VLAN41
   network 192.168.41.0 255.255.255.0
   default-router 192.168.41.254
   domain-namemyDomain.com
________
TASK: Exclude a block of IP's for VLAN (40 & 41), just in case we require some static IP's
RESULT:
ip dhcp excluded-address 192.168.40.1 192.168.40.20
ip dhcp excluded-address 192.168.41.1 192.168.41.20
On Switch 2
TASK: Add new VLAN names for VLAN (40 & 41)
RESULT:
vlan 40
vlan 41
_______
TASK:  Add VLAN (40 & 41) interfaces with no ip address
RESULT:
interface Vlan40
no ip address
interface Vlan41
no ip address
Step 2 - Set STP Priority
ON SWITCH 1 (core)
TASK: Add new VLANs to spanning-tree
On our SWITCH1 (core), we have this line of code,
          spanning-tree vlan 3,10,20,50,900,999 priority 24576
config t
spanning-tree vlan 3,10,20,50,40,41,900,999 priority 24576
RESULT:
Note: vlan 40 and 41 now added.
Step 3 - Update Po-Groups on Switch 2  and Switch 1 (core)
Putty into both and copy/past
Switch 2 - Port-channel1
Switch 1 - Port-channel2
TASK: ADD new vlans to Po-Groups
Config t
HARV-RHO-SW2(config)#interface Port-channel1
HARV-RHO-SW2(config-if)# switchport trunk allowed vlan add 40,41
HARV-RHO-SW2(config-if)#exit
HARV-RHO-SW1(config)#interface Port-channel2
HARV-RHO-SW1(config-if)# switchport trunk allowed vlan add 40,41
HARV-RHO-SW1(config-if)#exit
Step 4- Add new VLANs to OSPF as passive interface
On Switch 1 (core)
We have this line of code
router ospf 100
router-id 192.168.1.10
log-adjacency-changes
passive-interface Vlan10
passive-interface Vlan30
passive-interface Vlan50
passive-interface Vlan500
network 192.168.0.2 0.0.0.0 area 0
network 192.168.1.10 0.0.0.0 area 0
network 192.168.30.254 0.0.0.0 area 0
network 192.168.33.254 0.0.0.0 area 0
network 192.168.51.254 0.0.0.0 area 0
network 192.168.99.5 0.0.0.0 area 0
network 192.168.200.254 0.0.0.0 area 0
TASK: OSPF - Add new VLANs(40 & 41) to OSPF as Passive Interface
******* Begin Here  *********
config t
router ospf 100
passive-interface vlan40
passive-interface vlan41
!Not sure about these lines of code, I do not think required as I am mirroing VLAN 10 (old vlan) so new vlan 40, 41 should be similar
network 192.168.40.254 0.0.0.0 area 0
network 192.168.41.254 0.0.0.0 area 0
******* End Here  *********
RESULT:
router ospf 100
passive-interface Vlan40
passive-interface Vlan41
Hope order is correct so I do not bring down my trunk links the next go around.  Please correct task order if you don't mind.
Much appreciated!
Looks fine except for a few points -
1) you do not need SVIs on the other switch if it is not routing. So you are creating them with no IP address assigned. But you don't actually need to do this
2) you do need to add those "network ..." entries under the OSPF configuration but you should still make them passive interfaces.
Adding a vlan to the port channel on both ends should not bring the link down.
That said i always do these sort of things out of core hours just in case.
Hope it goes well when you implement the changes.
Jon
So the order in which to apply TASKS is correct?
also just to clarify the following TASK  based on your comments.
On Switch 1 (core)
router ospf 100
config t
router ospf 100
!WE SHOULD ADD THIS LINE OF CODE
RESULT:
router ospf 100
Better??
Again thanks...your feedback have been a tremendous help!
Yes, better for the OSPF configuration.
The only sligtht change i would make to the order is as soon as you create the new vlans then assign the STP priority to them before creating the SVIs and configuring the DHCP.
Apart from that it all looks good.
Jon
