Adding VLANs to a Port-Channel (Nexus 5K)
mfurnival
Level 4
Level 4
Can't find the answer I am looking for anywhere...
What is the preferred order of operation when adding additional VLANs to a Port-Channel already in trunking mode?
Do I add it to the physical port first then the port channel? Or the other way round?
Reza Sharifi
You just add the new vlan to the Portchannel.  It will then propagate it to all the ports that are bounded to that Portchannel.
Reza Sharifi
Great - thanks. Is that a new thing with Nexus or does IOS behave the same?
It is the same for most IOS versions.
I have VTP in Transparent mode.
Will that make any difference?
